Ok , I put longer wheel studs in the back axles so I could run a different rim.[thicker hub section]
Was : 14x6" factory rallyes with 225/70/14 Daytona tires.
Now Is : 16x9" Chrysler Conquest Factory Optional rims w/ 245/45/16 Yokohama AVS sports.
So now on any road with an uneven surface, including my street, there is a rattle now coming from the rear axle area...
I think it is the rear sway bar connections making noise as they appear to be the originals.
I believe going to the short sidewall tire has removed some of the give/cushion effect the tall 14" tires.
Any suggestion on alternate causes, shock manufacturers, and sway bar bushings, etc.
Have installed KYB Gas-adjusts before [other cars] and was reasonably happy with them.
It also has super stock springs underneath it.
Couldn't find a much wider tire in High performance rubber/design- rated @ 186+mph !
