Author Topic: heater box mounting  (Read 1137 times)
Offline 30below
heater box mounting
« on: June 22, 2009 - 04:24:11 PM »
On the 3 studs that stick thru the firewall to mount the heater box,is there just the nuts that tighten against the firewall,or is there a plate that slides on first?
Offline quapman
    • Auto-Grip on Facebook
Re: heater box mounting
« Reply #1 on: June 22, 2009 - 09:16:19 PM »
There's no plate, but there is a hook inside the vent, where it mates to the cowl, that holds the box up and in.
« Reply #2 on: June 22, 2009 - 09:28:11 PM »
A hard item to find. I don't think they're being re popped at all. You could make one from a threaded stud and bend it into a J with a picture of it next to a ruler. They're on E bay once in a while.
Offline 30below
« Reply #3 on: June 23, 2009 - 09:16:51 AM »
Thanks,i have the hook,was worried about tighting the nuts against new paint.Maybe ill use some small rubber gromets on the studs first.
Offline quapman
« Reply #4 on: June 23, 2009 - 04:54:59 PM »
It wouldn't hurt to put some flat washers between the firewall and nuts.
Offline RusTy/SE
  • Just havin' fun
« Reply #5 on: June 23, 2009 - 05:09:43 PM »
The correct heater box attaching hardware should have the washer - similar to the attaching hardware used on seat frame studs underneath the floorpan. The 'washer' diameter will be slightly smaller on the hardware used to attach the heater box.
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline 30below
« Reply #6 on: June 24, 2009 - 09:26:24 AM »
Thanks everyone.
