Author Topic: Need Location Of Gas Tank Braces  (Read 1269 times)
Offline 340SIX
« on: June 23, 2009 - 04:10:32 PM »
I know the brace that hold the tank and straps is angled some. Does anyone have measurements where they should be installed?
Need the location measurements of where they go?
I know they angle some and are not straight.
Would love to have a Diagram of the proper location showing fron the center or edges.
Also Thinking  maybe it would be better to install them prior to install of the one piece trunk floor
Offline DMZ73
    • http://www.pbase.com/dmz73/
Re: Need Location Of Gas Tank Braces
« Reply #1 on: June 24, 2009 - 12:27:45 AM »
Yknow,  I ran into this problem last year.
First I mocked up the straps in the floor of the trunk pan, without the pan on - it was not easy!
I took some measurements from the framerail.
Then what I did was set the straps down on the floor, set the tank on top an made measurements.
Then I did the same thing upside down.
Hope this gives you some ideas, without a measurement off-hand.
Best,
Dan
Offline 340SIX
« Reply #2 on: June 24, 2009 - 09:57:15 PM »
Body shop cut the old pan out and gave the car back with nothing also ruined the 2 parts of the new one so i have nothing to go on.
I now have a the new single part trunk floor and was hoping someone had a tank out and could take pics or measure and note what they have.
Thanks for the reply
kevin :cooldancing:
« Reply #3 on: June 25, 2009 - 09:17:17 AM »
The braces are straight on my '73 Challey, the frame is wider at the rear.
 The braces are 10" apart on center, & aproax. 18" from the inside of frame to center of brace at the rear (my left measured 18", right 18 3/8") 14 1/4" at the front.
Offline Sean
    • My Cuda Restore
« Reply #4 on: June 25, 2009 - 11:00:15 AM »
Would this be the same for a Cuda?  I'll be putting my trunk braces in shortly and am curious as well.
Sean
« Reply #5 on: June 25, 2009 - 08:57:04 PM »
Sean
I would not assume they are but probably.
Offline 340SIX
« Reply #6 on: June 26, 2009 - 01:15:02 PM »
Thanks what is it from the rear and front of the pan?
« Reply #7 on: June 26, 2009 - 04:16:44 PM »
yes
Offline MoparCar
« Reply #8 on: June 26, 2009 - 06:57:32 PM »
I have pictures showing the proper dimensions, but everytime I try attaching the pictures it say the upload files are full. Not sure. I've resized the pictures and split the files very small so I'm thinking its not me. I'll try them later.
Wes
Offline 340SIX
« Reply #9 on: July 06, 2009 - 10:38:18 AM »
Wes
Email it to me at fast340six@yahoo.com
They maybe to large to attach.
I can put it in my pics on line and post with a link
Offline MoparCar
« Reply #10 on: July 06, 2009 - 11:08:04 AM »
I'll do it tonight when I'm home.
Wes
Offline HemiOrange70
« Reply #11 on: July 06, 2009 - 11:49:05 AM »
I just installed a new tank and braces on my 70 Challenger-if you wnat the measurements for a Challenger-let me know ans I will go measure them
Offline MoparCar
« Reply #12 on: July 06, 2009 - 02:23:11 PM »
Here's my measurement for the supports. This is on a 71 Challenger. Most measurements are from the edge of the frame rail lip as you will see (the top most part that is at a 90* to the rail).
Maybe these will help.
Wes
