Author Topic: sticking clutch  (Read 2282 times)
sleepychallenger
sticking clutch
« on: June 24, 2009 - 09:16:25 PM »
well i tried something fun tonight for the first time since i made it a 4 speed..... i dumped the clutch and let her rip. well, when i popped the clutch, at first the clutch stayed on the floor, then i let up on the throttle a bit and it popped up so i floored it through 1st and i popped the clutch pedal in, slammed it to second and popped it out,,, but the clutch stayed on the floor till i let up on the gas. i got a good roast on the rear rubbers, but i really started worrying about the clutch. any ideas
Offline Changin Gears
Re: sticking clutch
« Reply #1 on: June 24, 2009 - 09:20:48 PM »
Do you have a diaphram pressure plate and still have the over-center spring on the clutch pedal?  Those two don't play well together.
sleepychallenger
Re: sticking clutch
« Reply #2 on: June 24, 2009 - 09:33:35 PM »
for some reason i cant post a pic of the pressure plate and it keeps saying that the upload file is full. it is a hays pressure plate and i do have a over center spring.
Re: sticking clutch
« Reply #3 on: June 24, 2009 - 09:35:47 PM »
Does it have 3 fingers or about 20 (that the throw out bearing presses on)?
Re: sticking clutch
« Reply #4 on: June 25, 2009 - 01:38:01 AM »
this is typical for a Diaphragm clutch which is why I hate them , there is no other reason I can think of for the clutch pedal to stay down
sleepychallenger
Re: sticking clutch
« Reply #5 on: June 25, 2009 - 09:07:47 AM »
it is a 3 finger
Re: sticking clutch
« Reply #6 on: June 25, 2009 - 10:46:28 AM »
is the linkage binding ?
sleepychallenger
Re: sticking clutch
« Reply #7 on: June 25, 2009 - 12:32:24 PM »
dont think so, it only does it when i am high throttle shifting.
Re: sticking clutch
« Reply #8 on: June 25, 2009 - 08:38:06 PM »
Bad drivers engine mount?
Re: sticking clutch
« Reply #9 on: June 25, 2009 - 09:02:58 PM »
Loose screw behind the wheel..................................................................  :smilielol:
sleepychallenger
Re: sticking clutch
« Reply #10 on: June 25, 2009 - 10:22:05 PM »
just put a new one in like 2 or 3 weeks ago. shouldnt be bad.
there is, but i dont know if that is the problem this time  :smilielol:
sleepychallenger
Re: sticking clutch
« Reply #11 on: July 12, 2009 - 09:23:44 AM »
so is the 3 finger clutch what i want with the over center spring or no? the clutch is doing the same thing when i down shift and really hit it. but the only difference is the clutch does not go down, it just slips really bad.
Re: sticking clutch
« Reply #12 on: July 12, 2009 - 06:54:11 PM »
You got a borg n beck clutch Drew.  The over center spring belongs in there.  You may need to back out on the adjustment. Or if it has been slipping bad, you may need to replace it from scorching it
Re: sticking clutch
« Reply #13 on: July 13, 2009 - 07:29:43 AM »
Drew...Did you check the NEW motor mount??.. Not uncommon for the parts store variety to break.
Offline jeryst
Re: sticking clutch
« Reply #14 on: July 13, 2009 - 08:58:10 AM »
Dont know if this helps, but I had a 68 GTS that did exactly the same thing. Stock motor, 4-speed, etc.
Turned out that it was too much play in the pilot shaft.
