Help with rear sway bar
Author Topic: Help with rear sway bar  (Read 704 times)
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« on: June 25, 2009 - 06:49:32 AM »
Can someone please tell me the length of the spacer used on the bolt connecting the sway bar to the spring mount?
Should the bar be level at ride height or does it not matter?
Thanks
Go Fast & Have Fun...
Re: Help with rear sway bar
« Reply #1 on: June 25, 2009 - 09:08:51 AM »
Stock 3"...if you have changed ride height much you will need longer or shorter
    • THE DODGE BOYS
« Reply #2 on: June 25, 2009 - 01:55:53 PM »
Thanks so should it be level with the ground?
« Reply #3 on: June 25, 2009 - 06:03:09 PM »
I can't say ...this thread may help you
http://www.cuda-challenger.com/cc/index.php?topic=54796.0
« Reply #4 on: June 26, 2009 - 01:12:42 AM »
the bar will function the same if it is level or not , just make sure it clears exhaust etc
Offline Aracer
« Reply #5 on: June 30, 2009 - 02:21:03 AM »
     At ride height it points to the front eye bolt and changes as the frame rises. Put a straight edge on top of the side bar, to verify.
