Author Topic: Pock marked steel part  (Read 1501 times)
Offline Purple73Cuda
« on: June 25, 2009 - 12:49:35 PM »
I have a used pinion snubber I want to use to replace the worn out one on my 8 3/4 rear. I blasted all the rust off of it. The bracket is pocked marked. I wanted to smooth the metal a little before I prime and paint it. I know it is where no one will see it. I still want to make it look nice and maybe learn something in the process.
How would you smooth the pock marks? What product would you use? Would you prime it first and then put filler over it?
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline ksierens
    • 70 Challenger Resurrection
Re: Pock marked steel part
« Reply #1 on: June 26, 2009 - 11:11:52 AM »
I would use a self etching primer and filler over that.
Kurt - SE Michigan
« Reply #2 on: June 26, 2009 - 12:04:46 PM »
What type of filler? Maybe an aluminum filler like Aluma lead? Is there someone that sells self etching promer in a spray can? I don't have a paint gun yet. I was planning on using spray cans, since my big compressor is not hooked up yet and the garage is full of stuff
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline Sean
    • My Cuda Restore
« Reply #3 on: June 26, 2009 - 04:15:22 PM »
What is a pock mark?   :clueless:
Thanks in advance!
Sean
« Reply #4 on: June 26, 2009 - 06:00:00 PM »
might be easier to just buy another for 10 bucks that needs no work and do your painting on it :2thumbs:
Offline cwestra
« Reply #5 on: June 26, 2009 - 10:12:55 PM »
I sprayed mine with Eastwood Rust Encapsulator then thin coat of filler.  Sanded down and sprayed again with Encapsulator.  Then painted.  Too bad no one will ever see it.
Corey - in Northern Indiana
« Reply #6 on: June 26, 2009 - 10:38:57 PM »
Thanks in advance!
Sean
A pock mark is a divot left from the metal that has rusted out. It leaves an irregular surface.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline 4 speed fish
« Reply #7 on: June 26, 2009 - 11:34:40 PM »
Use mar glass.It is alot stronger then filler.It will not flex and crack like filler.
Offline 71chally416
    • The Streetwalker
« Reply #8 on: June 27, 2009 - 02:05:31 AM »
That's all those things in Mick Jagger's face  :2thumbs: :smilielol:
Offline Sean
    • My Cuda Restore
« Reply #9 on: June 28, 2009 - 02:19:11 PM »
OK, got!
Thanks!
Sean
