Author Topic: Front and Rear Window Chrome  (Read 522 times)
Offline kmyles
« on: June 25, 2009 - 01:38:41 PM »
Does anyone know of a way to attach the front and rear window chrome to a challenger. I don't have the nubbings there to use the clips and I would rather not drill holes to use the screw type clips. Might a guy use some sort of adhesive like the urethane that was used to install the windows??? :clueless:
 :1zhelp:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Re: Front and Rear Window Chrome
« Reply #1 on: June 26, 2009 - 01:10:40 AM »
gluing them down will pretty much distroy them when you go the replace the windshield , you need to find a way to attach the clips by screwing them in or welding in new pins or ....
Offline Marty73
  • '73 Challenger
« Reply #2 on: June 26, 2009 - 03:24:07 PM »
Maybe use a dab or two of epoxy for each clip? lot less permanent then welding or making new holes in the car
Comin' at ya like a herd of turtles
Offline kmyles
« Reply #3 on: June 28, 2009 - 01:03:36 AM »
Has anyone ever done this???? :clueless:
_________
Kevin
« Reply #4 on: June 28, 2009 - 03:20:09 AM »
Can`t see that having enough strength to hold
