Author Topic: body cart/dolly thoughts?  (Read 1335 times)
Offline leithal
« on: June 26, 2009 - 10:18:56 AM »
In getting things ready for the resto I am looking at body cart/dolly options.  Something I've seen several times is individuals supporting their auto bodies on the rocker pinch welds.  What do you think of that idea for our Cuda/Challenger's?  I'm a bit reluctant to do that and am considering building my own that would have very heavy latitude rectangular stock and then use longitude square tubing mounted in the front, mid, and rear.  The reason for that is because I will need to replace both rear frame rails and want to keep everything in place.
Offline 426HEMI
Re: body cart/dolly thoughts?
« Reply #1 on: June 26, 2009 - 10:58:51 AM »
I dont know without having braces from front to rear on that.  I dont know if it would bend or not placing everything out of alignment.  Guess I will see what others think on this also.  what all will you have off the car when you do this?
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline leithal
« Reply #2 on: June 26, 2009 - 11:52:34 AM »
Well I purchased the car with both quarters removed, the rear footwell pans and trunk are almost gone.  My plan is to begin at the rear of the car by replacing the rear frame rails then the trunk.  I will then continue on with the rest of the entire floor.
Offline dutch
« Reply #3 on: June 26, 2009 - 06:30:45 PM »
I would build myself a decent frame construction, strong and square the same length as the carbody.  You have to be able to take measurements and maybe clamp parts to it.  :2cents:
*** Bart ***
« Reply #4 on: June 26, 2009 - 07:18:17 PM »
I would think the front spring hangars would make a good mounting point for the rear
Offline leithal
« Reply #5 on: June 26, 2009 - 10:06:46 PM »
Dutch, Bullitt, I agree that some type of frame jig is the proper direction and I was looking at the front spring area today.   I would also want to brace and square it with that very rear cross member that the frame rails attach to.
