Vacuum Leak at carb base gasket....
Author Topic: Vacuum Leak at carb base gasket....  (Read 8739 times)
Offline 67vertman
  • Member since 9-23-2005
« on: June 27, 2009 - 04:00:49 PM »
…Murphy’s Law is too true, while getting everything buttoned up and dialed in after installing my manifold and carb I noticed a loud whistling sound coming from the carb base.  I rechecked all the fittings, lines and bolts, but it still processed.  So, I grabbed the carb cleaner and started looking for the vacuum leak, when I sprayed around the base of the carb the idle changed, found the leak.  So, I pulled the carb and checked the gasket everything good there.  I grabbed a straight edge and checked the straightness of the carburetors/manifold base and everything is straight however there is some pitting on the manifold base.
So what could be causing this leak? And more importantly how do I fix it.  I am thinking of adding another base gasket. What about a gasket sealer?
Offline the_engineers
Re: Vacuum Leak at carb base gasket....
« Reply #1 on: June 27, 2009 - 04:55:15 PM »
Do not glue down a carb.  Have you tried a new gasket?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline 67vertman
« Reply #2 on: June 27, 2009 - 04:58:56 PM »
Not yet, as I had to order one, as all that parts store in my area where out.   :stomp:
« Reply #3 on: June 27, 2009 - 06:47:34 PM »
Should be a thick gasket?   How many holes in the carb intake?
wagesofsin
« Reply #4 on: June 27, 2009 - 07:08:06 PM »
never, ever, ever use sealer on a carb base gasket, youll snap the ears off quicker than well, anything.
just make sure its got a clean mating surface, and try again.
Offline 67vertman
« Reply #5 on: June 27, 2009 - 07:15:45 PM »
It's was a thin gasket supplied by Edelbrock, with eight mounting holes and eight holes in the manifold.  I used the four inboard ones to mount the carb,  Should I use the outside ones?
« Reply #6 on: June 27, 2009 - 07:37:20 PM »
The other holes may be sucking air
Offline 67vertman
« Reply #7 on: June 27, 2009 - 11:59:26 PM »
Didn't thank of that Alan I will check it out.  The new gasket I ordered only has four holes.
Offline NoMope Greg
« Reply #8 on: June 28, 2009 - 12:44:44 AM »
Is it an Edelbrock carb or a Carter AFB or AVS?  72blunblu had been having the same issue using the Edelbrock gasket with his AFB.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline 67vertman
« Reply #9 on: June 28, 2009 - 12:50:37 AM »
Edelbrock......you would think that they would supply good gaskets with thier carbs.  :swear:
« Reply #10 on: June 28, 2009 - 03:36:43 AM »
Make Sure the linkage is not interfering with the manifold anywhere & lifting the carb
Offline 67vertman
« Reply #11 on: July 04, 2009 - 04:17:40 PM »
Ding Ding Ding, we have a winner.  Alan hit it on the head.  :2thumbs:
Someone, before me, tapped and Hilo coiled the outside holes, and drilled through into the intake.  I had to re-tap the hole and put in a new Hilo coil....no more vacuum leak.   :jumping:  :jumping:  :jumping:
