Author Topic: Oil Change Info  (Read 1500 times)
Offline troutstreamnm
Oil Change Info
« on: June 28, 2009 - 06:48:08 PM »
Just some general info for you guys that have not changed the oil yet on your new Challenger.  All bolts are metric so FYI.  The ground effects plastic plate has 4-10MM bolts and it slides out from underneath the front air dam once unbolted.  The oil pan drain plug is a 13MM bolt and was on fairly tight from the factory.  Note the green factory markings.  The oil filter was almost welded on from the factory and I broke my filter tool trying to remove it. :swear: Had to drive all over town to get a replacement.  The oil after 1000 miles seemed fairly dirty which surprised me.  Added 7-qts of Mobil 1 0W-40 and a new Mobil 1 oil filter.  The Challenger is happy now  :bigsmile:  A couple pic for your entertainment.
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline Changin Gears
Re: Oil Change Info
« Reply #1 on: June 28, 2009 - 08:39:22 PM »
Every new Mopar I ever bought had the factory filter on incredibly tight.  Had to chisel one off.
Offline resq302
Re: Oil Change Info
« Reply #2 on: June 28, 2009 - 10:22:10 PM »
Yup.  Had the same thing with my 05 Ram that I bought new.  Ive learned that whatever the cost, the dealership gets the first oil change.
Anyone notice that the factory oil filters have the Factory Installed label on the top of the oil filter?
Offline MJS73
    • Mike's 1973 Challenger
Re: Oil Change Info
« Reply #3 on: June 30, 2009 - 01:18:45 PM »
I thought there was a TSB that stated that only 5W20 was recommended to avoid damage to the MDS system...? I know it's true of my Ram.
www.mikes73.com
Re: Oil Change Info
« Reply #4 on: June 30, 2009 - 02:38:48 PM »
The 6.1L comes with 0W-40 Mobil 1 from the factory and that is what is recommended in the manual and on the oil fill cap.
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline MJS73
Re: Oil Change Info
« Reply #5 on: June 30, 2009 - 05:04:39 PM »
That makes sense. The 6.1 doesn't have MDS.
www.mikes73.com
