Author Topic: Are these HEMI mounts? YES!!!! The Schu's came in  (Read 4988 times)
Offline BIGSHCLUNK
« on: June 28, 2009 - 11:24:44 PM »
Maybe just me....?
« Last Edit: July 13, 2009 - 10:34:28 PM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: Are these HEMI mounts?
« Reply #1 on: June 29, 2009 - 03:04:11 AM »
right side isn`t , left looks home made
Offline BIGSHCLUNK
« Reply #2 on: June 29, 2009 - 09:06:15 AM »
Thanks Neil thats kinda what I thought. That motor has always sat just a hair high in the pass side....  :banghead:   ... another project!
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #3 on: June 29, 2009 - 11:32:11 AM »
Bigs, do you know if your K member is a regular E body K member or is it a Hemi K member?  I'm assuming its a standard e body K member that someone fabricated their own home made engine mounts.
There would be two avenues you could choose from to replace the existing mount system.
1. Buy the Schumacher mount conversion system.
2. Have your K member converted over into an original design Hemi K member.
If you choose to go route 2, then you would need to contact Mega Parts for the K member conversion. they're the only ones I know of doing this. This would entail sending your standard E body K member to them and they would convert it over. Route 2 system is a total of 6 parts plus studs and quite a bit of money to do. But then it does look OEM corrrect. Schumacher system is about $260 bucks and a whole lot less time and run around.
Below is a picture of what an original Hemi K member looks like.
And here's a link on the Hemi mount parts needed.
http://www.megapartsusa.com/products.asp?cat=10
« Reply #4 on: June 29, 2009 - 01:01:49 PM »
I am not convinced your block has the correct holes in it to put a stock Hemi mount into it
« Reply #5 on: June 29, 2009 - 01:16:00 PM »
You may be right on that CP.
Wasn't there some Hemi blocks made that are B R/B mount configured?
Offline BIGSHCLUNK
« Reply #6 on: June 29, 2009 - 01:43:48 PM »
The block is an '01 Mopar Pewrformance...
No it's not a HEMI K, but she is a true R/T (was a big block) I (assume) the original K
I never really took a good look at them till now... they just dont look correct....
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #7 on: June 29, 2009 - 02:16:38 PM »
yes there is , I have had to modify 2 so far to take stock mounts , royal pain to do it though , I just do not see the monut holes in the right side of that block + having the 440 mount on the right side it would have to have some sort of ear to attach to .
 This could become a lot of work to correct
Offline BIGSHCLUNK
« Reply #8 on: June 29, 2009 - 02:25:56 PM »
This has got me scared now! That rt side.....    we've had stuff like this in the yard, BAD BAD BAD!  :swear:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline BIGSHCLUNK
« Reply #9 on: June 30, 2009 - 12:08:31 AM »
I looked around A bit more tonite when we were tacking up the subs............ trans mount shot too!!! I'm sure the lack of motor mounts took it out!!  :crying:  More work more $$ I don't mind fixing/restoring s#it but I hate stupid s#it!!!  :villagers:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #10 on: June 30, 2009 - 12:51:58 AM »
Offline BIGSHCLUNK
« Reply #11 on: June 30, 2009 - 08:37:23 AM »
BTW  TC  I'm sure schumacher will be the way I go!  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #12 on: June 30, 2009 - 11:47:59 AM »
That's what I plan on doing too. BTW, make sure you get a Hemi trans mount. They have additional material with a higher durometer rating.
Offline BIGSHCLUNK
« Reply #13 on: July 01, 2009 - 08:35:18 AM »
durometer...?  :clueless: Thats a new one for me TC. But I'm definetly replacing the trans mount too!
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline BIGSHCLUNK
Re: Are these HEMI mounts? ARUZZA??????
« Reply #14 on: July 01, 2009 - 10:33:35 AM »
I just got off the phone with Schumacker. I told him about my mounts. He says they sound like ARUZZA mounts. And if I did not have issues with them, there are no saftey issues, leave 'em. He did not try to pressure a sale in any way! Now I've been digging around and find NO website for Aruzza High Performance.  :banghead:  I'd sure like to see a pic of the mounts they have.  Anyone got any ideas??
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
