Author Topic: VIN sequence vs. actual build sequence.  (Read 2180 times)
Alaskan_TA
« on: June 30, 2009 - 09:30:06 PM »
Hey gang,
I get asked about this all the time, so I used the July IOTM to illustrate something for you all;
www.hamtramck-historical.com
If anyone has ANY 1970 Hamtramck broadcast sheet(s) please help me out with copies or scans? I have very few of them for cars built on assembly line 2. Every sheet I get to see helps with my research.  :wave:
Barry
Offline 2TAGS
Re: VIN sequence vs. actual build sequence.
« Reply #1 on: July 02, 2009 - 11:17:12 PM »
I've heard that groups of cars went down the lines that were the same color -is this true?  Are the T/A and R/T in your example the same color?  Happy B-day BTW!
1971 'Cuda 340
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #2 on: July 02, 2009 - 11:22:26 PM »
Good catch, 2TAGS!  :thumbsup:
Happy B-day, Barry!   You get  a banana dance for that!  :bananasmi
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
« Reply #3 on: July 02, 2009 - 11:35:34 PM »
Great info as always , Barry.  :clapping:  Thank you  :2thumbs:
Alaskan_TA
« Reply #4 on: July 02, 2009 - 11:43:19 PM »
Nope, one is pink & one is purple.
I have not seen any evidence that same color cars were produced in a row.
Offline KZ
« Reply #5 on: July 06, 2009 - 03:21:14 PM »
this may or may not have been queried here before but didn't Chrysler keep any master copies of build sheets? I would find it hard to believe that they just shoved a broadcast sheet in their cars w/o registering them SOMEWHERE in a master file, i.e. notebook, folders, etc. for a means of recordkeepin gfor the company
Alaskan_TA
« Reply #6 on: July 06, 2009 - 10:19:32 PM »
They did keep records on microfishe of the IBM cards. The IBM card were inserted into a card reader & then the sheets were printed out at over 80 stations all over the plant, hence the word "broadcast".
But the records from 1968 & up were lost, either destroyed in a fire or flood depending on what version of the story you hear.
If you have a 1967 or older car, you can get a copy of what they have on it for (I think it is?) 25 bucks.
