Hello all from Kansas
Author Topic: Hello all from Kansas  (Read 2323 times)
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Hello all from Kansas
« Reply #15 on: July 02, 2009 - 10:58:30 PM »
 :wave: Welcome, Charles!
Lots of nice people here with lots of knowledge!
Ask away!  You know what they say, the only stupid question is the one you don't ask!  :grinyes:
Offline cudadave72
  • you motorboatin sob!!!
« Reply #16 on: July 05, 2009 - 10:22:27 PM »
Welcome Charles!! Looks like you have a great start and a nice Chally!!! :2thumbs:
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline WorkingOnItStill
« Reply #17 on: July 05, 2009 - 11:02:53 PM »
Thanks all for the welcome's , small update I found a 440 and 727 for cheep its out of a 1977 motor home, good running motor did a run test for a half hr and worked the trans a bit. I did a test stab with it today and it looks like i have to change the tail shaft its a good 4 to 5 inches to short for the trans cross member mount.  :working:
Charles
"Flying is learning how to throw yourself at the ground and miss." - Douglas Adams
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #18 on: July 06, 2009 - 07:22:51 AM »
Nice score on the 440 too bad about the trans being the short style I believe if I remember correctly that the whole transmission will have to be taken apart just to change the tail shaft it needs a longer output shaft to go with the longer tail shaft.  :rofl:
Go Fast & Have Fun...
Offline hezzel
  • Matching numbers 383 Magnum ,727 at and 3:23 rear
« Reply #19 on: July 06, 2009 - 04:29:53 PM »
Welcome  :wave: nice chally :thumbsup:
1971 Dodge Challenger R/T
2019 Toyota Rav4 Hybrid
Offline acudanut
« Reply #20 on: July 06, 2009 - 05:12:55 PM »
Yes, that's true. you should have asked first! Motorhome 440's ain't the best either because of the cams, compresions, oil pans, exhuast and motor mounts.  It can all be made to work though. Good luck and welcome FROM GARDNER KANSAS.
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
« Reply #21 on: July 06, 2009 - 11:01:31 PM »
Welcome aboard from South Philly!  Another e-body SAVED!  :bananasmi
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
Offline 70B5Cuda
« Reply #22 on: July 11, 2009 - 02:55:54 PM »
Hey,
  I am up the road in Newton and work at Hawker. Where do you work?
70 B5 Barracuda 6.1/6speed project
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #23 on: July 12, 2009 - 09:16:19 PM »
should be a nice ride when your done,,to bad about the tranny,,there right about having to take apart and replace alot
72rtchallenger
what happens in the garage
stays in the garage
« Reply #24 on: July 12, 2009 - 09:27:22 PM »
Sweet ride 72rtchallenger, ya i have found out the hard way but im learin as i go :cooldancing: i have found a long shaft that should work out. I went ahead and did a test stab "after changing the oil pan and motor mounts".looks good all i think i have left is getting the trans rebuilt. I don't have clue one where to start so i will prob take it some wher.
Offline acudanut
« Reply #25 on: July 13, 2009 - 01:45:40 AM »
 Find "RD" in here. He lives in Kansas also and can build you one cheap. What are you doing for an exhaust ?
    • THE DODGE BOYS
« Reply #26 on: July 13, 2009 - 07:38:12 AM »
looking sweet  :2thumbs:
Offline acudanut
« Reply #27 on: July 17, 2009 - 12:31:56 AM »
NOTHING ??
