if you can do the sheet metal work it will save you lots of money,,i replaced both quarter panels and trunk pan an inner fenders,,requires spot weld drill bits and hand tools,clean and prep all metal that stays after removing old sheet metal,then i predrilled the areas on my new sheet metal for welding,,took a mig welder and welded in the holes,,a touch of grinding to the welds and they look like factory spot welds when finished,then fill in seam areas ,i used alot of por-15 paint and epoxy putty ,takes patience and elbow grease,,but only cost me in parts,,its is alot of work,,but doing the work your self is knowing that its done right,,you never know what a bodyshop will hide unless you see the whole process yourself,,
