Author Topic: Help - Horn does not work  (Read 7741 times)
Offline t1971Chally
« on: July 03, 2009 - 07:54:36 PM »
Hey guys,
I have moved on to my next electrical gremlin......the horn! It does not work!!!   I have look at the wiring from the horns back to the firewall and on the inside as well....everything seems to be ok.  I have also checked the horns to ensure they work by touching them with a hot wire from the battery and they both work.  I believe part of my problem is that I am missing the horn relay.  I am just not sure what it looks like and from the reading I have done on the forum it sounds as if it plugs into the top of the fuse panel below the dash.  If this is correct.....then I am missing the horn relay.  I have looked on the forum and performed some searches regarding this subject however each time I get a lead the link or picture is broke or missing.  Does anyone have a picture of what it looks like and where it goes?  Also, where can I get one?
Thanks
Ted
Ted
1971 Dodge Challenger 440 Magnum
:cheers:
Re: Help - Horn does not work
« Reply #1 on: July 03, 2009 - 08:07:59 PM »
I was in your shoes once. Someone removed my relay. I guess the original might have been bad, but if you go thru the trouble to remove it, why not replace it?   :pullinghair:
Yes, it is on your fuse block, but they varied thru the years. It is a rectangular silver thingie.
Offline t1971Chally
« Reply #2 on: July 03, 2009 - 08:18:43 PM »
Hey sorry guys I forgot to mention that it is a 71 Challenger 440.
Ted
Ted
:cheers:
« Reply #3 on: July 03, 2009 - 09:12:13 PM »
The relay also functions as the key-in buzzer, that's probably why it was removed.
  It should be easy enough to wire in a common 3-prong relay to serve the purpose
http://cgi.ebay.com/ebaymotors/New-Horn-Relay-Mopar-Challenger-Cuda-1971-1972-1973_W0QQitemZ350069389999QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item5181c2faaf&_trksid=p4506.m20.l1116
Offline quapman
    • Auto-Grip on Facebook
« Reply #4 on: July 03, 2009 - 09:16:44 PM »
I've had plenty of cars with missing relays and jerry-rigged horn switches. Plug in a new relay and viola!
I guess those buzzers must have REALLY been annoying back then!
« Reply #5 on: July 03, 2009 - 09:30:49 PM »
Annoying is not the term I'd use  F!@#$%^&* noise
Offline quapman
« Reply #6 on: July 03, 2009 - 09:34:24 PM »
Now that you mention it, mine's in the console until I get the car back on the road.  :roflsmiley:
Offline t1971Chally
« Reply #7 on: July 03, 2009 - 10:37:43 PM »
Hey Bullitt,
Thanks for the picture!!!  I started laughing at the some the other posts.....it seems I stirred up an emotional topic!!! :roflsmiley:
Thanks for everyones help.....I will watch the EBAY posting and see if I can round one up.  Who knows, maybe I will end up unplugging it  ;D
Ted
Ted
:cheers:
« Reply #8 on: July 03, 2009 - 10:45:37 PM »
You'll never forget & leave your keys in  :bigsmile:
Offline quapman
« Reply #9 on: July 04, 2009 - 06:53:51 AM »
You can fold-over or cut off one of the tabs and the horn will still work, but no buzzer. I don't recall which tab, sorry.  :eek4:
Offline 422STROKER
  • Member Since 6/3/06
« Reply #10 on: July 04, 2009 - 08:32:07 AM »
I think it's the lonesome one, mine is broken off and I always wondered why.  seems like the correct relay is tougher to find locally.
Tom
Tom
Offline CUDA JAS
  • vroooooom!
« Reply #11 on: July 09, 2009 - 12:37:49 PM »
Tom
Has anuyone checked Rock auto.  Thay have a tonne of parts.  I got a realy for my 74 there.  (same deal, no horn, no realy)
Jas
74 'cuda 360/727
Just call me a gearhead!
« Reply #12 on: July 09, 2009 - 05:51:14 PM »
Jas
Unfortunately they do not list a horn relay for our models with the fourth terminal, although I suspect the 3-prong relay for the '74 model would work for horn only.
Offline VTMopar
« Reply #13 on: July 16, 2009 - 09:49:43 PM »
Not to Hijack this too much -- but what about the opposite?    I was driving down the road and all of sudden my horn goes off and it won't quit!     I pulled the horn ring and disconnected the wire inside the steering wheel -- no change.    Ultimately I had to pop the hood and disconnect the horns.     Might it be this relay sticking or something?    This was with my '74 -- no other previous wiring issues and I hadn't touched it!    Any ideas?
VT Mopar
VT MOPAR
« Reply #14 on: July 16, 2009 - 11:13:57 PM »
could be the relay although I would suspect a ground short in the column 1st
