Author Topic: i know a lot are wondering  (Read 1373 times)
sleepychallenger
« on: July 04, 2009 - 12:12:31 PM »
what is a cheaper option than buying aluminum heads? 906,915....?, what size valves, what do we tell the head shop to do? looking for performance. Just putting it out there for general knowledge.
Re: i know a lot are wondering
« Reply #1 on: July 04, 2009 - 12:28:43 PM »
nothing is cheaper then the stealth heads from 440 source ,
 the best heads are the closed chamber iron heads , I add hard exhaust seats & larger valves to them & spend about 10 hrs porting them & i have very specific ways to port them to get excellent results from them , typically a set will run $1200 to port machine , add hard seat & new valves + you need springs to match your cam
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #2 on: July 04, 2009 - 12:34:00 PM »
Chryco, how are the heads from Aerohead?  Good?  Bad?  They have the closed chamber design.
http://www.aeroheadracing.com/id6.html
« Reply #3 on: July 04, 2009 - 12:37:17 PM »
lookslike they are priced right for the machine work done on them , but no port work
« Reply #4 on: July 04, 2009 - 12:40:17 PM »
Thanks!  Reason I was wondering about Aerohead because when I got my 383 engine, it had no heads and was looking for replacement for them and found those guys.  Didn't order from them so I have no idea what they are like to deal with.
Offline 71chally416
    • The Streetwalker
« Reply #5 on: July 04, 2009 - 12:44:09 PM »
Aerohead is part of Indy.
« Reply #6 on: July 04, 2009 - 12:57:52 PM »
Cool, thanks!  :thumbsup:
moparniac
« Reply #7 on: July 04, 2009 - 01:06:52 PM »
Drew is that a numbers motor 383 ?
sleepychallenger
« Reply #8 on: July 05, 2009 - 01:10:24 AM »
mine, yes, except for one head being replaced in the 80's and one rebuild...why do you ask?
sleepychallenger
« Reply #9 on: July 05, 2009 - 09:27:55 AM »
do they work though. i have read other threads about how they had to be modified and finding the right kind of gasket and nothing but bad stuff about 440source. has anyone here used them and can provide numbers?
moparniac
« Reply #10 on: July 05, 2009 - 09:39:13 AM »
Drew I would buy a use worked over set of eddy rpms for about the same price..... seems like the sources best product is the stroker kits but everyone knows they need checked over as well....  :working:
SHOP SHOP SHOP........... :2cents: Source kit is like $2000 know..... you can shop around and get new quality pieces for the same amount.....
sleepychallenger
« Reply #11 on: July 05, 2009 - 09:43:45 AM »
i am definately shopping around, would love to find a set of good heads (whether RPMs or whatever) for about the same price as 440 source. still have to wait till i get that kind of money but the time will come. I am just looking for what all options i have and what all could be done with a factory set of heads.
« Reply #12 on: July 05, 2009 - 12:04:43 PM »
well I have used a # of the 440 source kits with no issues , Just because they blow up doesn`t mean that the engine was machined or clearanced properly + I personally have never had an issue with dealing with Brandon , he has treated me well . On the other hand I would never use a set of his rockers  & while the price on the heads cannot be beat they still may not be worth the $$ , I have continued to use Iron heads with a lot of port work on most of my builds or I have stepped up to better heads than the Stealth or Eddys if I am using alum heads
sleepychallenger
« Reply #13 on: July 05, 2009 - 12:14:22 PM »
has anyone used the 440 source heads? inputs?
Offline 71chally416
    • The Streetwalker
« Reply #14 on: July 05, 2009 - 01:09:22 PM »
 :iagree: They are both clones of the stockers but Iron heads will make more power with all else being equal and don't require a compression increase.
