Author Topic: My oil gauge/reading  (Read 2788 times)
Offline miketyler
    • www.miketyler.net
Re: My oil gauge/reading
« Reply #15 on: July 11, 2009 - 01:51:19 PM »
those numbers seem about right to me. I'd roll with it. Chances are you can go buy a new sender and your OEM guage will be good to go as well. I wish my temp gauge would look like yours after running for an hour idling.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline 422STROKER
  • Member Since 6/3/06
« Reply #16 on: July 11, 2009 - 07:07:01 PM »
Those pressures sound fine.  Rule of thumb is 10 psi for every 1K rpms.
Tom
Tom
Offline JayBee
« Reply #17 on: July 11, 2009 - 07:33:41 PM »
Thanks for your input Mike/Tom and everyone else.
Another update. Decided to change the oil and filter (again) and I'm a lot happier. Gained between 2 to 4 PSI from the first posted readings using the mechanical gauge. Now the factory gauge reads just like it did last season (before this spring's first oil/filter change). Also the needle doesn't go down to that "scary low" area anymore either. I dunno, maybe it was bad oil or a bad filter.
I appreciate everything you all have helped with. Now I've learned how to test gauges, have a mechanical oil pressure gauge (to loan out around here, if needed) and now I know how much pressure is good enough. This site is the best.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline 422STROKER
« Reply #18 on: July 12, 2009 - 07:46:52 PM »
Glad it's ok after all!
Tom :2thumbs:
Tom
Offline RusTy/SE
  • Just havin' fun
« Reply #19 on: July 12, 2009 - 07:56:38 PM »
It may be nothing but what brand oil filter was removed, what brand replaced it? No small amount of mishaps claimed when using Fram  :dunno:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline JayBee
« Reply #20 on: July 13, 2009 - 10:33:24 AM »
You sitting...a Mopar filter from the dealer was removed. I have a hunch it was sitting around for decades. The guy said there isn't much demand for them and they couldn't even find it for a month. Okay, still sitting...it was replaced with a Fram. For the eons that I've been doing oil chages in all my cars I've always used Fram or a generic and, knock wood, haven't had any problems.
John
2014 Toyota Avalon
Offline duodec
« Reply #21 on: July 14, 2009 - 12:40:54 AM »
Aren't current Mopar filters OEM'd from Fram?  I know a while ago they looked identical when taken apart (crappy cardboard end caps on the element, wimpy anti-drainback valve...).  Maybe it was just a bad filter, or (if it really was old) it failed on way or another.
I still stick with Napa Gold, Wix (top of the line, can't remember the name), or Mobil-1 filters based on past reviews and research, and cutaways submitted by MML reviewers many years ago.  Of course now they may all be made in China ca-ca, but then they were better.
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #22 on: July 14, 2009 - 02:09:58 AM »
I'd still replace the oil sending unit if you're going to keep using the dash readout.  My old Ranger pickup truck had extremely low oil psi according to the gauge.  After I replaced the sending unit, the psi was 3/4 up the gauge again.  Before changing the sending unit, a fresh oil change always made the low oil psi read a tad higher for about a week or 2 then it would drop to almost nothing.
I have a mechanical oil psi gauge in my cuda, it reads 15-20 lbs @ idle and 50-60 psi while driving.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline JayBee
« Reply #23 on: July 14, 2009 - 09:04:57 PM »
duodec,I'll keep those other filters in mind for the next oil change and hooD, your readings make me feel a lot more comfortable. Thanks guys.
John
2014 Toyota Avalon
