Author Topic: lets make my 390 stroker faster at the track  (Read 1053 times)
390stkr
« on: July 05, 2009 - 10:32:22 PM »
hi all
i have a 318 that i built into a 390. put a 4" crank in.
anyway here is my specs.
duster
68 318 block bored 30
stroker kit from speedomotive with diamond stroker pistons-forged
clevite rod and main bearings
6qt kevco oil pan and pickup
xe268h cam kit from comp cams 268/280 with .477/ .480 lift
summit billet timing set
heads cleaned up, 2.02/1.60 valves with shims to correct spring pressures
rpm air gap intake
650 speed demon carb.
exhaust is mans. with 2" pipes.......have pypes stainless x system race pro with tips ordered which in mandle bent 2.5 also got tti headers ordered.
auto 904 trans with shift kit
stock converter
rear is 8 3/4 with 391 gears....going to put a adj pinion snubber this week.
tires are 255 60 15 rear street tires running 20 psi. still seems to spin off the line.
best time to date is a 14 flat at 98 mph
i feel the car is faster than that.
Re: lets make my 390 stroker faster at the track
« Reply #1 on: July 05, 2009 - 11:55:14 PM »
well the Carb is at least 100 cfm too small , I generaly start with 2x the CI so 750-800 Proform or Holley HP would be my choice .
 The cam is small & being Comp grind will cost you some power , I would be looking at a Lunati grind
 What heads exactly are you using, any port work done , I bet there is some power lost there as well
 AT almost 100 MPH in the 1/4 you should be a second faster so traction is hurting you as well , some Nitto drag radials , & or suspension improvements would help a lot too , SS springs with clamped [U bolt ] front sections would help a lot , pinion snubbers are a mixed bag , they work but are bad on the street pounding against the floor
Offline the_engineers
« Reply #2 on: July 06, 2009 - 12:05:53 AM »
I got tired of the thumping and bumping associated with an adjustable snubber so I went the route of the Ground Pounder from Just Suspensions.  Much better!!!
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline tactransman
« Reply #3 on: July 06, 2009 - 07:09:18 AM »
to CC.com!
Terry-tactransman
Union, Mo.
« Reply #4 on: July 06, 2009 - 09:49:53 AM »
Stock torque converter isn't doing you any good.... Is this a street/strip car or strictly race?
  Send these guys your specs & they will make one for you
http://www.accperformance.com/Order/index.html
