Author Topic: Running a fuel regulator - where do you put it?  (Read 884 times)
Offline miketyler
    • www.miketyler.net
« on: July 08, 2009 - 11:24:14 AM »
I have a new Edelbrock carb that is flooding occasionally. My mech fuel pump pulses between 7.5 and 9psi and needs to be regulated. I bought a regulator and am in the process of installing it. Would like to see some of your installations. The unit is larger than I expected. I'd like to keep it out of site but if not, on top of manifold.
Any ideas or pics of installs?
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
moparniac
Re: Running a fuel regulator - where do you put it?
« Reply #1 on: July 08, 2009 - 11:41:19 AM »
 :working:
« Reply #2 on: July 08, 2009 - 11:52:26 AM »
as near to the carb as possible usually
moparniac
« Reply #3 on: July 08, 2009 - 12:11:07 PM »
The rear firewall isnt a bad option.....
Offline MrMopar440
« Reply #4 on: July 09, 2009 - 07:39:24 AM »
Mine is in about the same spot as Stroker's - but I have the bracket to drop it next to the carb (hangs off the two manifold bolts). Just have to make the time to move it.
Offline miketyler
    • www.miketyler.net
« Reply #5 on: July 09, 2009 - 10:11:27 AM »
cool - will the regulator stabilize the pulsing?
72' Cuda restomod
70 Mustang Mach 1
Offline shadango
« Reply #6 on: July 09, 2009 - 12:53:46 PM »
It didnt stabilize mine all that much...I am running a different brand..a spectre.
Offline MrMopar440
« Reply #7 on: July 10, 2009 - 08:17:07 AM »
I know that mine stays rock-steady now
Offline jackie
« Reply #8 on: July 10, 2009 - 03:17:47 PM »
here's mine
1970 challenger r/t, prostreet 438 ci. 4 speed
Offline shadango
« Reply #9 on: July 14, 2009 - 08:55:37 AM »
My spectre DIED just a die after installing...so a holley is going to be ordered soon....
Offline miketyler
    • www.miketyler.net
« Reply #10 on: July 15, 2009 - 08:48:50 PM »
Got all my parts in and put it together. No leaks! The unit comes torque striped from the factory at 2.0psi.  :clueless:
I cranked it up to 5.0psi and all good. Pulsing is gone. It did get a little warmer than I'd like but it idles steady as a rock.
72' Cuda restomod
70 Mustang Mach 1
