Author Topic: ***Side Window Channel Weatherstrip? ***  (Read 4450 times)
« on: July 08, 2009 - 10:58:54 PM »
I was by Moparals place today & was challenged to install his replacement side window weatherstrip that goes in the stainless channel on the leading edge of the glass..I failed.
  The pieces he has are soft rubber flocked  and a little too wide to go in the channel on his '70 Barracuda. My '73 Challenger has the same style channel which is a simple "H" when viewed from above and the rubber, while similar in appearance, is made of a harder non-flocked material.  Alan also has spare windows that have different style channels with additional stainless material which extends on the inside-side of the piece.
  Looking at Metro Moulded Parts site they list 3 different items (pictured below)
   So the questions are
1. Is there a year or model style difference for these channels?
2. Any definitive knowledge of which of these is correct for a specific year/channel?
3. What are your opinions of the weatherstrip you have used?
4. What technique did you use to install your weatherstrip?
These look most like my '73s
VS 7-A Rear Roll-Up Window Seals. Two pieces, 20" long. Replaces OEM #2782560-1.
Appears to be the same as above but with flocking added.
VS 7-A/FL Rear Roll-Up Window Seals. Two pieces, 20" long. Black, electrostatically flocked.
These look like what Alan has for replacements
VS 7-K Flocked Rear Roll-Up Quarter Window Seals.
« Last Edit: July 08, 2009 - 11:04:28 PM by Bullitt- »
Offline torredcuda
  • Epping NH joined 11/23/03
Re: ***Side Window Channel Weatherstrip? ***
« Reply #1 on: July 09, 2009 - 06:53:57 AM »
VS7-A
0> This part also fits the following autos:
1962 DODGE DART
1962 PLYMOUTH BELVEDERE
1962 PLYMOUTH FURY
1962 PLYMOUTH SAVOY
1963 DODGE 330
1963 DODGE 440
1963 DODGE POLARA
1963 PLYMOUTH BELVEDERE
1963 PLYMOUTH FURY
1963 PLYMOUTH SAVOY
1964 DODGE 330
1964 DODGE 440
1964 PLYMOUTH BELVEDERE
1964 PLYMOUTH FURY
1964 PLYMOUTH SAVOY
1965 DODGE CORONET
1965 DODGE CUSTOM
1965 DODGE POLARA
1965 PLYMOUTH BELVEDERE
1965 PLYMOUTH FURY
VS7-K
1970 DODGE CHALLENGER
1970 PLYMOUTH BARRACUDA
Right off there website.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
« Reply #2 on: July 09, 2009 - 07:43:14 AM »
Torred...you missed the last line on those Fits list for VS7A & VS7A/FL (these appear in a search for '70 Barracuda but not '70 Challenger)  See all vehicles...  You get the same list of models for each item including under 1970 is Barracuda but not Challenger
If I know my Mopars this has to be a miss print  A & E body would not be the same..Right?
1970
    * DODGE DART
    * PLYMOUTH BARRACUDA
    * PLYMOUTH DUSTER
    * PLYMOUTH VALIANT
But I also could have gone a little deeper, seems that under '73 you get a 4th option that appears to be the only option for '71-4
VS 7-M  Rear Roll-Up Quarter Window Seals.
1971 DODGE CHALLENGER
1971 PLYMOUTH BARRACUDA
1972 DODGE CHALLENGER
1972 PLYMOUTH BARRACUDA
1973 DODGE CHALLENGER
1973 PLYMOUTH BARRACUDA
1974 DODGE CHALLENGER
1974 PLYMOUTH BARRACUDA
« Last Edit: July 09, 2009 - 07:58:16 AM by Bullitt- »
« Reply #3 on: July 10, 2009 - 06:56:36 PM »
I guess I'll jump to the obvious conclusion
ALAN you've got 71-later side window glass in your car
