70 _ 71 rear spoiler plates
Author Topic: 70 _ 71 rear spoiler plates  (Read 4666 times)
wagesofsin
« on: July 09, 2009 - 07:43:06 PM »
can i get some basic dimensions of the under decklid plates please.
and maybe a pic of them mounted.  :bigsmile:
http://www.yearone.com/serverfiles/fbshopmain2.asp?input=spoiler&SM=1&SC=1
thank you.
Offline scf100
  • FAST LANE FOREVER!
Re: 70 _ 71 rear spoiler plates
« Reply #1 on: July 09, 2009 - 10:12:11 PM »
can't help with pics but I think I have a brand new pair for sale...if you need them
1970 Challenger R/T convertible 383…. 4-speed…3.91 suregrip
Triple Black
« Reply #2 on: July 09, 2009 - 10:14:00 PM »
70 plates are different then the 71-74 cudas
Offline hotrod98
    • Maniac Musclecars
« Reply #3 on: July 09, 2009 - 10:22:59 PM »
As far as I remember, 71 was the only year that the gull wing was available. Most options were discontinued in 72. Were any early 72's built with a gull wing or did they just have leftover 71 deck lids?
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: July 09, 2009 - 11:57:16 PM »
As far as I know, the Gull Wings/Go Wings were not an option for '72.  You probably could by one at the Parts counter, I don't see why you couldn't back in '72.  I picked up a '71 Gull Wing style Go Wing for my car seeing that if one could go to the dealer to pick up a wing, that would be the one to get.  I have not mounted it yet though.
If I understand your question correctly, my trunk lid underneath does have the 4 holes for the wing to be mounted and assuming the other holes are what I think they are for, it has the provisions for the plates to go underneath.  My car was an early '72 if that matters, SBD 8/17/1971.
Or do you mean if there were left over '71 trunk lids with wings already mounted?  :clueless:
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #5 on: July 11, 2009 - 03:55:20 PM »
This is how I did mine,,using a ruler or tape measure,center the wing on the trunk lid.Use masking tape to protect the finish on the car and double check that the wing is centered by measuring the left and right side distance from the side edge of the trunk lid..
To find the rear mounting hole locations on both sides you have to measure on a 70 to 71 challenger measure from the bottom edge of the trunk lid forward,following the contour of the trunk lid 8-1/2" which is to the back of the spoiler leg rear stud,,,on a 70 cuda measure from break line(not bottom edge) on the trunk lid forward ,following the contour of the trunk lid 5-7/16" on the 71 cuda it is 8-1/8" to the back of the spoiler leg rear stud..
Using the spoiler leg studs as a guide,find the forward mounting hole locations (measure the distance between the 2 studs on the spoiler leg and transfer that measurement forward from the rear mounting hole location) then drill 4 mounting holes 5/16" and mount the spoiler legs and gaskets and spoiler,,this is how its outlined in a yearone catalog and when you have that done you can figure out were the braces under the trunk mount and were to drill the holes,,I used u-nuts after I drilled the holes and secured the braces with bolts to the u-nuts,,if you can get a yearone catalog it has a small picture and these instructions,it was very helpful when I installed mine,,and was the only reference I had and mine turned out perfect,,you should find the catalog if your unsure as I know when  its once drilled its permanent
72rtchallenger
what happens in the garage
stays in the garage
  • 72 to 70 clone
    • cardomain
« Reply #6 on: July 11, 2009 - 04:44:34 PM »
72rtchallenger
stays in the garage
wagesofsin
« Reply #7 on: July 11, 2009 - 04:51:52 PM »
i appreciate the link, i just wanted to see em mounted, and some basic dimensions, ill be making my own plates, i already know how to mount the wing.   :bigsmile:
im pretty sure ive got them worked out.   :2thumbs:
  • 72 to 70 clone
    • cardomain
« Reply #8 on: July 11, 2009 - 05:39:16 PM »
there 6"  on one end and widen as they go to the other end at 6-1/8"as the lip curls and 11" long...the bolt pattern is 9-3/4" from end to end centered on bolt holes..the holes on outer ends are 3" centered width and the inner bolt holes are 2-3/4" width the center stud holes are 4-3/4" off the outer end holes to center
72rtchallenger
stays in the garage
  • 72 to 70 clone
    • cardomain
« Reply #9 on: July 11, 2009 - 05:51:31 PM »
i saw some on ebay at $29 apiece ..as they do work better
72rtchallenger
stays in the garage
wagesofsin
« Reply #10 on: July 11, 2009 - 05:53:51 PM »
thats what im making!!
whats the link?
  • 72 to 70 clone
    • cardomain
« Reply #12 on: July 11, 2009 - 06:18:51 PM »
the above post is for ebay,,the measurements i gave are from my own car,and as close as i could measure
72rtchallenger
stays in the garage
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #13 on: July 11, 2009 - 06:19:12 PM »
Here is a 70 in the first picture and a 71 in the second picture.
wagesofsin
« Reply #14 on: July 11, 2009 - 06:23:46 PM »
he doesnt have the passenger side, only the drivers, i found some for 55.00 a set !
http://www.megapartsusa.com/proddetail.asp?prod=108-FP205
and i dont need 'cuda mounts bro, but i do appreciate the pics.
