Author Topic: 70 _ 71 rear spoiler plates  (Read 4667 times)
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: 70 _ 71 rear spoiler plates
« Reply #15 on: July 11, 2009 - 06:25:38 PM »
i hope you get what you need,,hope i helped
72rtchallenger
what happens in the garage
stays in the garage
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #16 on: July 11, 2009 - 06:27:00 PM »
Sorry, I knew something was wrong.
I havn't had a chally with a wing yet so that one passed on me.
wagesofsin
« Reply #17 on: July 11, 2009 - 06:32:02 PM »
all good, i may put a wing on my 'cuda as well!!
so you did good.   :2thumbs:
  • 72 to 70 clone
    • cardomain
« Reply #18 on: July 11, 2009 - 06:36:15 PM »
i dont know if the braces come with hardware but you will nee the special nut that attaches the leg studs to the plate,,they thread on to hold the wing in place and has outer threads to put another nut on to hold the plate to the leg stud
72rtchallenger
stays in the garage
wagesofsin
« Reply #19 on: July 11, 2009 - 06:50:49 PM »
ill look into that, i can make that if needed, but the plates for cheap is to good to pass on. having a full plate(s) means less time to actually get other things done.   :bigsmile:
  • 72 to 70 clone
    • cardomain
« Reply #20 on: July 11, 2009 - 07:03:19 PM »
you will need it,,it threads onto the stud and goes flush against the upper part of the brace and the nut goes flush on the bottom side of the brace,,this secures the spoiler and keeps the stress off the trunk lid,,it has a nut fitting on one end and then has a threaded sleeve that passes thru the brace so you can put a nut on it,,this puts all stress on the brace,not the trunk lid
72rtchallenger
stays in the garage
wagesofsin
Offline sprecks
« Reply #22 on: July 11, 2009 - 07:41:17 PM »
Here they are installed on my car. Left then right side.
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
Offline sprecks
« Reply #23 on: July 11, 2009 - 07:46:38 PM »
I agree with 72rtchallenger. I recommend getting the correct hardware. I did mine with just the plates at first and then bought the correct studs and nuts. Made life alot easier. They are special. If they aren't adjusted right, the pedestals put a dip in the deck lid.
Jay
you can call me Jay
« Reply #24 on: July 11, 2009 - 08:11:02 PM »
Sprecks
Are these mounts for both 70 and 71 ?
Or are they for one specific wing and year?
wagesofsin
« Reply #25 on: July 11, 2009 - 08:21:45 PM »
thanks for the pics, yea, i can actually make the hardware. so im cool there.
Offline sprecks
« Reply #26 on: July 11, 2009 - 09:53:24 PM »
Sprecks
They are listed in the catalog as fitting both. Weather they are "correct" for both years, sorry, I'm not sure.
you can call me Jay
