Author Topic: A833 Clutch Kit Recommendations?  (Read 5559 times)
Offline cwestra
« on: July 11, 2009 - 11:27:09 AM »
Getting ready to order a clutch kit for my 340 6-Pak.  Any recommendations on mfr. and model?  Should I replace the throw-out bearing or can I check to see if it needs it first?
Bushing or needle bearings for pilot?
Corey - in Northern Indiana
sleepychallenger
Re: A833 Clutch Kit Recommendations?
« Reply #1 on: July 11, 2009 - 12:14:06 PM »
i always replace the throw out bearing and a pilot bushing. not sure on brand/type clutch though
« Reply #2 on: July 12, 2009 - 08:20:12 AM »
I use Borg & Beck/ Long style McLeod clutches , I can get you part #s in a few days
Offline hemidude426ci
« Reply #3 on: July 16, 2009 - 03:16:16 PM »
When the Centerforce in my 'Cuda finally needs to be replaced I will absolutely throw a McLeod in there!
1970 FC7 440-6 'Cuda 4spd  Track Pack N96
Gone:
1970 Challenger R/T 440 6pack 4 spd N96
1970 Superbee 440 6pack 4 spd
1967 Shelby GT350
« Reply #4 on: July 17, 2009 - 04:01:43 AM »
either pilot brg is good , I generally try to use the bronze bushing if the hole is in the crank
Offline vinb
« Reply #5 on: July 17, 2009 - 06:57:37 PM »
Mcleod : 10.95
part # 360156 plate
part # 260121 disc
Check to make sure of your application....
Offline cwestra
« Reply #6 on: August 09, 2009 - 09:43:22 PM »
For street use, will a Mc Leod 75109 clutch & pressure plate kit work well for my AAR?
« Reply #7 on: August 09, 2009 - 11:29:44 PM »
I will have to look for that #
Offline cwestra
« Reply #8 on: August 10, 2009 - 10:30:24 AM »
What don't you like about your Centerforce?
Offline ShelbyDogg
« Reply #9 on: August 10, 2009 - 03:07:01 PM »
Centerforce aor any diaphram style clutch will stick to the floor while power shifting.
Just happened to a friend of mine. He says he always shifted and drove it hard with no problems. We had a BBQ with all of our Mopar friends and many were doing burnouts in the street. He just watched and didn't want to "tear up" his car.
When he leaves, he can't help but punch it in 1st gear, then hit second. Guess what? Pedal stayed on the floor when he lifted his foot and at the same time the gas pedal got pushed in hard.    I yelled "Chevy Clutch"
Offline cwestra
« Reply #10 on: August 10, 2009 - 03:15:02 PM »
Are all Centerforce clutches diaphram type?
Offline ShelbyDogg
« Reply #11 on: August 10, 2009 - 03:25:45 PM »
Don't know unless you ask Centerforce themselves. You can tell it is a diaphram style if it has the small release fingers all the way around the center.
« Reply #12 on: August 10, 2009 - 09:43:23 PM »
every C Force clutch I have seen is a Diaphragm type
Offline cwestra
« Reply #13 on: August 26, 2009 - 09:42:20 AM »
Anything on this P/N, CP?
« Reply #14 on: August 26, 2009 - 10:22:23 AM »
the kit you are looking at is just another Diaphragm clutch
 I would use a 360953 or 954 PP with a 260821 disc
