Thanks guys!
The bracketry is nearly the same as it was. I spent several hours trying to
configure the power steering pump and A/C compressor brscket.
After several tries, I finally figured out the power steering pump brackets.
As of right now, I have to re-do the A/C and alternator bracket. Such a P.I.T.A!!!
I also have several bolts that I need thar thread into the block.
Since I have the 340 alternator support bracket, I need the bolt that goes into the block, to the left of the fuel pump.
I also need to find out what bolt size is correct on the A/C bracket to the head.
I tried everything I had, coarse thread, machine thread.. I'll post a pic later.
I bolted on the tie rod ends, mounted the front tires and cleared out the torsion bar receptacles in the frame. They were full of tar, dirt, old grease, bugs, rust...
Nasty...
I also need to clean out that nasty gas tank with some kerosene, and put it back on the car.
tomorrow I'll get her on the ground and re- mount the doors and fenders.
It sure would be nice to have a complete car again.
I don't even care if it's all one color, just as long as it's one piece again...
Dan
