Author Topic: Desert resurrection! 1973 Challenger - Updated pics! 4-16-2012!  (Read 48602 times)
Offline quapman
    • Auto-Grip on Facebook
What's it look like with the taillights in?
Offline DMZ73
    • http://www.pbase.com/dmz73/
I'll snap a pic tomorrow with the lights in.
Very strange... :clueless: :dunno:
I did cut down the bracket, and put it back together. looks MUCH better  :thumbsup:
lots to do tomorrow-
Dan
Offline DMZ73
 :villagers: :swear: :stomp: :swear: :banghead: :banghead: :banghead: :swear:
Mig wont penetrate that bracket worth a darn.. Did it 3 seperate times.
Found the source of the distortion.....
The lower mounting flange the left of the two larger holes was distorted 1/4" or more rearward.
Will end up cutting down the other bracket to match.
oh well............... :bigsmile:
Offline ShelbyDogg
My mig doesn't get hot enough if you plug into a wimpy circuit and or use a cheap extension cord with it. I plug right into a dedicated 20 amp circuit. I can weld 1/4 steel in one pass with my Lincoln Sp-100, 110v welder.  Try it again without an extension cord. I'm guessing that you're using one?
Offline DMZ73
Thanks for the advice!
Rob If I dont use an extension cord, I blow the circuit.
If I do, I can weld and get OK penetration.  I have a two other factors that contribute-I  had to adjust the settings, & I also have an extra long Mig feed hose.  (Miller Cricket 110)
I am getting an electrician to come out and install  a dedicated circuit in the garage so that this does not happen in the future.
I typically don't weld the heavier stock at home. It pisses me off that this happens
I'll take it to work and have it re-welded. grrrr...
Thanks again for your input!
Dan
Offline DMZ73
Pic from the Left to the right of the tail panel with 5/16" removed from the bracket.
Seems like this takes forever!
Bumper on, bumper off. Bumper on,adjust bumper.. bumper off. Adjust bumper, BUmper on, Bumper off, adjust bumper..
Overall- Now the right side needs to come toward the body.
More to come.
Dan
Offline DMZ73
after a few weeks recovering from some back pain, I'm back on the car.
Now that the bumper is alligned, I have moved on to bigger and better things---
well not really, but it was a nice try.
I spent a day fabbing up some bumperette valence fillers.
I made them to nest into the original openings, to be welded in place with minimal warpage.
Pics to follow.
Patterns available for those that are interested.
Dan
Offline DMZ73
Sorry for the crappy Iphone pics.
here's the pattern I cut out.
Fully formed
and in place
other side
Dan
Offline quapman
No dual exhaust?
Offline Aloid
  • Simi Valley, CA
Really inspiring work DMZ...  You make this look easy.
'73    (O[   ]||||[   ]O)
////  NAME CHANGED TO 360FISH  \\\\
Offline DMZ73
Dual Exhaust-Yes. gotta have it.
but not there yet. When I do get some exhaust, then I'll fab the cutouts.
Round is most likely. I think it's cool.
Aliod- It aint easy. Its a slow and steady project. Somedays far too slow. I wish I was  further along
Dan
Offline Mentally Challenged
If you use the exaust I gave you, then you won't need cut outs.  :bigsmile: Looking good Dan
Chris, Ohio
Offline DMZ73
Chris- yes, I absolutely intend on using the exhaust system of yours!
Eventually making dual exhaust to the valence.
Dan
Should be pretty easy to do, the put the mufflers in the correct area.
Chris, Ohio
Offline DMZ73
Some better pics of the bumperette valence fillers
Yes, I had to adjust the A line on the QP again, just to make sure it was right on.
Onward and upward. :2thumbs:
Dan
