Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
** Bondo UV Cure Any Feedback? **
« previous
next »
Print
Pages: [
1
Author
Topic: ** Bondo UV Cure Any Feedback? ** (Read 3311 times)
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
on:
July 13, 2009 - 10:00:01 PM »
Doing body filler research & ran across this UV Cure Bondo. I have used a traditional filler but was looking for something easier to spread thin & give more work time. IF I can find a UV source for my garage this looks like the ticket.
Anyone with any experience with this product?
http://solutions.3m.com/wps/portal/3M/en_US/3MAutomotive/Aftermarket/Products/Product-Catalog/?PC_7_RJH9U5230GE3E02LECFTDQCEK3_nid=ZXMWTKXGGPgsFDKXQL309JglG2GKHB5WJGbl
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
torredcuda
Sr. Resident
Epping NH joined 11/23/03
Re: ** Bondo UV Cure Any Feedback? **
Reply #1 on:
July 14, 2009 - 09:19:16 AM »
That is a glazing and spot putty not a filler so it`s only meant for very thin,small spots over primer.It also dries in 10 minutes so not a lot more time to work it than regular type.
Logged
Jeff
72 Barracuda 340/4spd Torred
70 roadrunner 383/auto In-Violet
70 Duster 360/auto drag car (Petty Blue soon)
04 Ram 2500 5.7 Hemi
Bullitt-
Permanent Resident
Reply #2 on:
July 14, 2009 - 08:10:57 PM »
Let me tell you where I'm at & what I'm thinking.
Patch panel on rear qtr. is in... I have put body filler over the entire effected area & sanded down with a long board & in the contours roughed the shapes back. Also as I sanded if a small high spot showed up I pinged it back down.
So my immediate need is for a thin skim coat that may be a little thicker in some areas bot nothing more than 1/2 dime thick. This 2-part filler is thick & gets thicker quickly, in 90+ degree weather, I have tried reducing the activator but at best it starts to harden within 5-minutes. Long term I would like to skim coat the entire car.
What is appealing to me about the UV cure Bondo is it states "Cures fast in direct sunlight in less than 10 minutes." so I think if I apply it in the subdued light of my garage it will stay pliable until it is exposed to a strong UV light.
Logged
Huntsville, AL
72cudamaan
Resident
Reply #3 on:
July 14, 2009 - 10:30:46 PM »
how bout a high build primer instead?
Logged
If I cant fix it, it's broke
Andy (phukker whither)
miketyler
Resident
Reply #4 on:
July 14, 2009 - 10:55:42 PM »
Maybe a high build primer if you alreay have the profile work done. I have used the Dolphin glaze stuff. It is thin and a little runny but it dries fast and sands REAL easy. I use it for final surfacing before primer topcoat. The easy sanding is what makes it such a great product.
Last Edit: July 14, 2009 - 10:59:10 PM by miketyler
Logged
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
elitecustombody
Full Member
Supra collector
Reply #5 on:
July 16, 2009 - 11:19:54 AM »
if all you want to do is skim the car, use Evercoat G2 high build primer, it's a well proven product, I don't know what I would do without this stuff in my shop, I've been using this for over a decade
Logged
Stefan B
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
