Author Topic: 750 speed demon baseline  (Read 618 times)
Offline leanburn
« on: July 13, 2009 - 10:42:18 PM »
i'm just fishing to see if there is someone else with a similiar build and running a demon. i have a 340 with eddy heads, 10.4:1 comp, hughes solid cam in the 245ish duration, 3200 stall.
 if there is anyone else with a similiar build i would love to see your setup, jets, squirters, cam colour, ect. thanks.
Re: 750 speed demon baseline
« Reply #1 on: July 14, 2009 - 02:13:37 AM »
First I would set the idle mix & idle speed & get a vacuum reading & install a power valve to match , then start tweaking it
