Author Topic: Pistol Grip Shifter Rebuild (Help Needed)  (Read 919 times)
Offline cwestra
« on: July 14, 2009 - 08:38:51 PM »
I'd like to rebuild my pistol grip shifter but not quite sure how difficult it is.  Anyone have any tips?
Corey - in Northern Indiana
Re: Pistol Grip Shifter Rebuild (Help Needed)
« Reply #1 on: July 15, 2009 - 03:04:52 AM »
the handle or the mechanism ?
 the mechanism is rwlatively easy just remove the 7/16 nut & plate from the side to side pivot push out the sleeve in the top bolt hole , pry the body apart & remove all of the levers in one piece , keep everthing in order , clean & re-grease everthing & reassemble
Offline cwestra
« Reply #2 on: July 15, 2009 - 07:11:57 AM »
Mechanism.  I did remove the nut and long bolt but wasn't sure how it came apart from there, and if it would be difficult to reassemble.  I see where the outer U-shaped bracket can be pried to release the internal components.  I'll try that.  I assume a standard bearing grease would work?  Thanks.
Offline tommyg29
« Reply #3 on: July 15, 2009 - 08:39:14 AM »
Any pictures on this?
I need to remove my shifter to replace the rubber boot which is torn.
« Last Edit: July 15, 2009 - 08:40:45 AM by tommyg29 »
Offline cwestra
« Reply #4 on: July 15, 2009 - 09:16:16 AM »
Shifter attaches to a bracket on the tail shaft through 2 bolts.  Remove the 3 linkages and these bolts and it should slide out.
