Author Topic: Exhaust Manifold Finish  (Read 758 times)
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
« on: July 14, 2009 - 09:33:59 PM »
What type of finish can be used on Exhaust Manifold's to protect them from rusting and is about a clear finish  ???
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
Offline 72cudamaan
Re: Exhaust Manifold Finish
« Reply #1 on: July 14, 2009 - 11:15:07 PM »
Cast blast or hi temp paint can be applied. Wouldn't recommend clear though.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline JoltinJoe
« Reply #2 on: July 14, 2009 - 11:28:34 PM »
What is the preferred finish since clear is out?
« Reply #3 on: July 15, 2009 - 03:07:23 AM »
Por 15 has a cast colored manifold paint that cures with heat & seem to be durable as long as the manifolds are clean when it is applied , Eastwoods also has a similar product
Offline resq302
« Reply #4 on: July 15, 2009 - 09:03:40 AM »
Ive never had any good luck with either POR-15 or Eastwood exhaust manifold paint.  The stuff I've found that has worked really well is the Nu-Cast from VHT paint and supposedly withstands up to 1200 degrees.  Color is dead on for fresh cast iron color too.
Offline JoltinJoe
« Reply #5 on: July 15, 2009 - 11:48:11 AM »
What I've found from VHT is: http://www.vhtpaint.com/flameproof.html  Seems to have changed the name and improved to 2K degrees.  Is this similar to what you used?
Anyone else have experience with any of these products?
Offline resq302
« Reply #6 on: July 15, 2009 - 02:16:19 PM »
If you look all the way down on the right side of the page, there is part number SP998 Cast Iron.  That is the one that I used.
