Author Topic: Pie pan sould be glue?  (Read 762 times)
Offline Nel
« on: July 14, 2009 - 11:16:04 PM »
I was wondering if the pie pan on the air cleaner sould be glue or just old there by the wing nut? If it's it was glue what should use?
Thanks
Offline bb71challenger
Re: Pie pan sould be glue?
« Reply #1 on: July 15, 2009 - 12:09:39 AM »
I have never seen a pie tin mounted with glue. Just placed on the air cleaner lid and the wing nut installed. It will not move around with the wing nut tightened down.
*Brett*
« Reply #2 on: July 15, 2009 - 02:54:39 AM »
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #3 on: July 17, 2009 - 09:38:52 PM »
There also should be a gasket between the pie pan and the carb. It helps provide a seal and keeps out contaminents. :2thumbs:
                                           Matt B.
Matt
« Reply #4 on: July 17, 2009 - 10:38:40 PM »
                                           Matt B.
You mean there should be a gasket between the air cleaner base and carb right?
*Brett*
« Reply #5 on: July 18, 2009 - 05:31:11 AM »
Correct! :2thumbs: It's just a round ring made of a soft composite material. There should be a lip at the top of the carb it sits right on and the air filter pie pan rests on the gasket.
                                                 Matt B.
Matt
Offline Nel
« Reply #6 on: July 20, 2009 - 09:15:55 PM »
Thanks for the info. I install every thing and I think it look realy good.
