Author Topic: heater box install  (Read 683 times)
Offline HemiOrange70
heater box install
« on: July 15, 2009 - 10:51:55 PM »
Just re-istalled my heater box after 4 years. Everything fit ( heater water lines and motor through firewall, but there is a gap on the passenger side top ducting. Is this normal from years of saging? Are there just three firewall motor bolts and the screws to the interior firewall?
Alaskan_TA
Re: heater box install
« Reply #1 on: July 15, 2009 - 11:30:33 PM »
There is also a threaded J-hook that helps support the back & hold it tight to the upper cowl, if you find it & install it, the gap will go away.
« Reply #2 on: July 16, 2009 - 01:00:07 AM »
There is a 1/2" foam seal on my non-a/c heater box between the box & cowl. I made one from some hardware store insulating strip with adhesive on one side.
« Reply #3 on: July 16, 2009 - 02:48:02 AM »
Thanks, I thought something pulled it up into the duct.
