Author Topic: which auto trans to build ?  (Read 1009 times)
Offline Bigwig
« on: July 16, 2009 - 10:49:49 PM »
i just bought a 73 Cuda and it came without a trans. It was an original 4 speed, but I want to convert it to an automatic. whats my best option here ?
Offline challengermaniac
Re: which auto trans to build ?
« Reply #1 on: July 17, 2009 - 01:11:31 AM »
I'm not the transmission expert on here, but I think you should be looking for a 727 to fit up to the small block.  A four speed automatic would likely require a lot of modifications to fit and make it work.  You could also go with a 904, but with so many 727's available, that will likely be your best bet.
Charlie
70 Challenger
69 Camaro RS
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
« Reply #2 on: July 17, 2009 - 04:03:46 AM »
note that the small block has the choice of either the 904 or the 727 , the 727 being heavier & more durable but slower for racing
 the big block also uses the 727 but in a larger housing , there is not other option for a stock bigblock
sleepychallenger
« Reply #3 on: July 17, 2009 - 10:05:04 AM »
it shouldnt be that bad to swap it, it should be mostly bolt on stuff, change the pedals out, and weld in the automatic trans tunnel. i am sure that most of the parts can be found right here on the site. i know i have some of what you would need, PM me for more info.
Offline tactransman
« Reply #4 on: July 17, 2009 - 11:14:05 AM »
If you do not have an auto already,go with the 727. It cost the same to rebuild and is stronger.
Terry-tactransman
Union, Mo.
wagesofsin
« Reply #5 on: July 17, 2009 - 11:50:11 AM »
ill buy all the 4 speed stuff if ya wanna sell it.
Offline vinb
« Reply #6 on: July 17, 2009 - 06:31:59 PM »
Put a stick in it....... :thumbsup:
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #7 on: July 21, 2009 - 07:39:01 PM »
keep it a 4 speed,,more fun to drive unless you plan on racing alot,,then i agree with wagesofsin,,would buy your 4 spd parts
72rtchallenger
what happens in the garage
stays in the garage
