Author Topic: Carb suggestions for a 496 Stroker  (Read 2837 times)
Offline ebodychallenger
« on: July 17, 2009 - 02:43:08 PM »
Hi
I have the following setup for a stroker 383->496. I would need your opinion about the carb choice.
Proform and Quickfuel are nowadays having good choices, but are there some principal differencies between them and what kind of experiences you have?
Crankshaft: 440 Source kit 383>>496, 4.250" stroke/6.535" rod.
Pistons: 440 Source .030 over, flat top -4CC, Compression Height, 1.320".
With 86cc heads, 11.0 CR.
Rings: Total Seal gapless
Camshaft: CompCams XR292HR-10 hydraulic roller. Duration @050 inch Lift: 242 int./248 exh. Duration: 292 int./300 exh. Lift .549/.537.
Lobe Separation 110 degrees.
Lifters: CompCams 8921, Pro-Magnum series.
Valve springs: CompCams 26120, beehive valve springs.
Retainers: CompCams 796, 10 degree
Heads: Ported cast iron, over 310 cfm @.600 lift
Rockers: CompCams 1.5
Intake: Mopar M1, single plane
Headers: Hooker Super Competition, primaries 2", 32"length, collector 3.5"
Ignition system: Mopar Perf. distributor, with MSD 6AL-2
Rear end with 3.55 gears, 3000 rpm stall converter.  The car will be mainly used on the street, but perhaps occasionally on the strip too... :burnout:
What would you be your recommendation for the carb?
« Last Edit: July 17, 2009 - 05:32:13 PM by ebodychallenger »
Re: Carb suggestions for a 496 Stroker
« Reply #1 on: July 17, 2009 - 07:24:24 PM »
I bought a Proform 850 last year. Although I only have a slightly hopped up 440, that thing is awesome!! I went 850, since it was the biggest that still was available with a choke. You might even want to go bigger??   :dunno:
Really, I slapped it on, adjusted the idle and fuel level and that was it. Jetting was dead on, and my car is quite scary when I nail it now on the hiway.   :grinyes:
wagesofsin
« Reply #2 on: July 17, 2009 - 07:53:12 PM »
proform actually custom built my carb for my 427, call em up, give em the specs.
« Reply #3 on: July 17, 2009 - 08:03:37 PM »
Yep, I'm just in between the choice of 850 or 950 cfm
Any experiences from Quickfuel carbs?
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #4 on: July 17, 2009 - 09:56:01 PM »
I like Pro Systems. I just had one built for my 543 stroker and it was right on the money. The throttle response is wicked. A lot of racers use Pro Systems carbs. Give them your engine specs and they will custome build one for you. The one they built for my motor was a 1000 cfm.
                                           Matt B.
Matt
Offline 73EStroker
« Reply #5 on: July 18, 2009 - 11:04:11 PM »
I run a Proform 950 on my 451. Pretty wild cam and indy EZ heads. No stumble and smooth all the way from idle to full throttle.
Barry (Salmon Arm)
Offline Oldschool
  • Member Since 9-05-06
« Reply #6 on: July 18, 2009 - 11:07:01 PM »
1050 Dominator.     :burnout:
Ken  --  In Georgia
« Reply #7 on: July 19, 2009 - 02:19:21 AM »
950 Proform would be my call , the Dominator is a great choice as well
Offline moper
« Reply #8 on: July 19, 2009 - 09:08:50 AM »
Yup. Minimum 950cfm.
Offline 71chally416
    • The Streetwalker
« Reply #9 on: July 19, 2009 - 09:32:16 AM »
                                           Matt B.
 :iagree:  They go on all my motors. Patrick at PS forgot more than most carb experts will ever know and he has testing equipment they don't have. Here's his take on carb sizing.
http://www.pro-system.com/pjames011900.html
Offline farmertan
« Reply #10 on: July 19, 2009 - 02:22:47 PM »
I'm a little bias because we live so close to pro systems but all our race cars had them on and if you give him the right specs on your motor it will be a bolt on and go part. We have never had a carb related issue.
73 340 4sp 2nd owner since 85    brett
moparniac
« Reply #11 on: July 19, 2009 - 02:24:13 PM »
I have a 950 hp for sale  :bigsmile:
