Author Topic: 17 x 9 inch wheel 5 inch back spacing  (Read 2236 times)
Offline autoxcuda
    • Spring Fling
Re: 17 x 9 inch wheel 5 inch back spacing
« Reply #15 on: July 19, 2009 - 01:16:02 PM »
Or is it you want to run only 5" backspacing in the rear and you want to rotate rims and tires?? yes i would like that option, but now i will look in to the hotchkis,that is an idea ??? thanks :2thumbs:
Maybe just run a 1/2 spacer in the back. But I understand, the 9.5 isn't really neccesary with the 275/40/17 tires and 5" backspacing would not need any spacers or need to run longer studs in the rear.
Is there any way a 17x9.5 with 5" backspacing is going to fit in the front of your Challenger?
I'm still wearing down my obsolete 245/50/15 comp ta's. But after that I'm stuck with with 17" and I will cram a 275/40/17 on a 17x9 5.5 backspace in the front of my A-body 68 Cuda somehow someway. I'll have to trim the lower front fender lip about 1" by 3" triangle I think.
Cutting or lipping that on you car might fit the 9.5 rims too?
That KMC hot wheel rim is a really nice looking rim that is very inexpensive too.
« Last Edit: July 19, 2009 - 02:46:52 PM by autoxcuda »
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
Offline drewcrane
« Reply #16 on: July 19, 2009 - 01:59:26 PM »
i found this wheel it is the dimensions i am looking for a 9.5 is just to tight
http://www.summitracing.com/parts/SUM-141-7965GM0/
the lower front fender lip about 1" by 3" triangle I think.  i did that too i rounded it,cause it will hit a large tire if left in the stock dimension :bigsmile:
« Last Edit: July 19, 2009 - 02:01:18 PM by drewcrane »
Offline autoxcuda
    • Spring Fling
« Reply #17 on: July 19, 2009 - 02:49:32 PM »
"the lower front fender lip about 1" by 3" triangle I think. "
So you've all ready cut back the fender. What tire and rims do you run right now?
Spring Fling XXX
April 22 & 23 2016
Offline drewcrane
« Reply #18 on: July 19, 2009 - 02:59:05 PM »
i have now on the car a 17 x 8 with a 4 inch back spacing,and a 255/40 zr17 goodyear f1, on all 4 corners great tire and wheel set up i just need as much tire as possible under the car :drool:
Offline IMNCARN82
  • LeDZeP
« Reply #19 on: July 19, 2009 - 09:02:47 PM »
Hey,You can try mine on if you need to.  17x9   5.0 b.s.   I need deeper wheels.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline drewcrane
« Reply #20 on: July 19, 2009 - 10:21:58 PM »
what wheels , post a pic,and we can hook up since we live in the same area,kinda :droolingbounce:
