Author Topic: AAR Transmission?  (Read 985 times)
Offline jmartin99
AAR Transmission?
« on: July 18, 2009 - 11:14:29 AM »
I have a friend that has a transmission that he believes to be from an AAR Cuda.  The numbers on it are:
OB302154
PP833B149  0051
He thinks that AAR transmission numbers start BS23JOB...  And that his is missing the BS23J but has the rest.
Does this sound right?  Is this an AAR Transmission?
Thanks!
Jeff
« Last Edit: July 18, 2009 - 11:16:05 AM by jmartin99 »
Re: AAR Transmission?
« Reply #1 on: July 18, 2009 - 11:31:41 AM »
an OB tranny could be any trans from a 70 car built at Hamtramck plant , ic could even be from an A body car
 the only possible way to tell is from the sequence # and that # seems too high to me to fit the 3 month window when the T/A series cars were built
Offline cwestra
« Reply #2 on: July 18, 2009 - 01:12:02 PM »
The last 4 digits on my numbers matching AAR trans are 0118.
Corey - in Northern Indiana
Offline aarcuda33
« Reply #3 on: July 18, 2009 - 05:01:16 PM »
I believe minus factory race cars and pilot cars AAR Cudas Vins started around
   Vin                               Build Date
 274---                             March 11 , 1970
 And went to
 311---                             April 20 , 1970
My AAR  vin is 307--- built   April 15,1970
« Reply #4 on: July 18, 2009 - 09:54:25 PM »
Does his vin make it more valuable then any other 70 sm blk 4 spd?   I know its the same gear ratios and such but the date make it better  for any ta/aar?
Alaskan_TA
« Reply #5 on: July 18, 2009 - 10:07:24 PM »
0B 302154 would be from an AAR Cuda. I have not heard of the car it matches before though.
The engines & transmissions had just the partial VIN listed, it is normal.
Can you or your pal email me with his contact information please? If I hear of the car it matches I will have the owner contact him (if I know how to find him).
Thanks!
Barry Washington
