Car runs, warmed up.....usual low, choppy idle I have mentioned elsewhere.....all of sudden, while driving, engine just dies...seems to happen if I do a hard turn......but not necessarily...sometimes just when cruising along at 35 or 30. It doesnt seem to bog or anything..,it just cuts out, almost like an electrical issue.....but I took the electronics down to autozone and they gave everything (igniton mod, volt regulator) a clean bill of health....I installed a new coild since the other new one was leaking oil....so i dont think its electrical.....
If I leave it in gear, sometimes it will restart momentarily while coasting.....but not always. If I try to restart immediately, no joy.
Remove air cleaner and there is usually some fuel vapor/smoke and I can smell gas in the carb...no external leaks on the carb though.....sometimes it will have a low pop in the carb.....and lots of smoke......Engine eventually restarts after a few minutes...usually is ok for a bit then might do it again...
When I put the eddy 1405 on it (replacing the 1407 that was on it), I set the float rise at 7/16" distance between the gasket and airhorn....drop seems to be a little more than it is supposed to be......could that be my issue?
I installed a fuel pressure regulator again (Holley 12-803) and pressure is now steady at 5 psi....when it stalled, the pressure gauge read 7 psi (!how?) but once it was running again it was back at 5.
At wits end here.
I guess my next step will be adjust the floats with less rise (bigger distance between top of float and carbgasket/airhorn body, right?)? Maybe I picked the wrong spot on the float for the measurement?
I am running orange springs on the rods right now.....would it be worth going to a lighter spring ?
I have been sticking very close to home testing this....afraid to go further than a mile or so....its getting very frustrating.
Thanks guys for bearing with my constant streams of questions......
