Hotchkis Suspension Mopar Open House Report and Pictures
Author Topic: Hotchkis Suspension Mopar Open House Report and Pictures  (Read 4147 times)
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: Hotchkis Suspension Mopar Open House Report and Pictures
« Reply #15 on: August 12, 2009 - 05:56:30 PM »
SWEET... Please tell us more I love all this tech talk :drool:
Its way over my head  :roflsmiley:
 :bigsmile:
Go Fast & Have Fun...
Offline ntstlgl1970
  • T a c o c a t
« Reply #16 on: August 12, 2009 - 06:29:57 PM »
I'd sure like to get my hands on those strut rods.
I've actually been toying with the idea of creating a front strut mount made from a chevy upper ball joint and a tubular threaded rod. Their struts would save me the trouble.
Have you seen these from Total control? (it's a ford part but it wouldn't take much to cut and thread the tube on the control arm end to work on a mopar....) These are very nice parts (a buddy has them on his Falcon) Since they are owned by Chris Alston's Chassisworks, maybe they would be interested in producing some one-offs
« Last Edit: August 12, 2009 - 06:34:42 PM by ntstlgl1970 »
« Reply #17 on: August 12, 2009 - 06:34:27 PM »
So, in taking the anti-dive out of the front end they needed to alter the pivot mounting location on the upper A arm.  When they did this, did they also alter the length and put additional camber gain in the arm design?
iIhaven't looked at those yet, but why not. I'm looking at putting a fox body mustang panhard bar under my Dodge.
Offline autoxcuda
    • Spring Fling
« Reply #18 on: August 13, 2009 - 04:30:02 AM »
I don't know for sure on the any change in length. If so, not much since you still have to get to the right alignment. I could see a slight camber gain by lowering the front A-arm inner pick-up point. But not a ton. The effective lowering would be about half the distance the front pick-up point moved down since the rear didn't move at all.
They explained purpose of moving the front arm of the upper A-arm down is to reduce bump steer. Yes, that reduces the anti dive some, but they told me it is not eliminated. A car setup from some handling has far less nose dive than the worst case senerio B-body 383 wagon, which share the same geometry.
« Last Edit: August 13, 2009 - 04:37:18 AM by autoxcuda »
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
