I installed rallye guages in my Cuda this spring.
The temp guage does not read at all.
The gas guage usually pegs at the full side, but will sometiems fluctuate down.
The gas gauge and fuel sender are new, so it should work. The temp guage I do not think I checked. The oil press guage is not hooked up yet.
So, I was thinking the proble could be the old wireing (especially the fuel gauge).
My plan was to run a jumper wire from the fuel sender tot he guage and see if it reads properly. Then try the same with the temp guage.
I was reading an old article today and is says these symptoms are somtimes caused by the stock regulator. So I think I will try a test light on the regulator first
Any other thoughts, or am I on the right track?
