Author Topic: Broadcast Sheet marked with a "B"  (Read 1061 times)
Offline cudafishin
« on: July 21, 2009 - 04:40:53 PM »
I finally received a broadcast sheet from the original owner of my 1973 Barracuda.  It was extremely brittle, so I laminated it to prevent further damage.  On the sheet, a large "B' has been drawn on the sheet with a black wax pencil (looks like it came from the factory).  Does anyone know what this means?  Possibly "B" for Barracuda-- or am I wrong?  I'm very happy to have this broadcast sheet since there was no fender tag that came with the car.
Alaskan_TA
Re: Broadcast Sheet marked with a "B"
« Reply #1 on: July 21, 2009 - 06:06:49 PM »
I finally received a broadcast sheet from the original owner of my 1973 Barracuda.  It was extremely   Possibly "B" for Barracuda
Yes.
The upholstery sales codes were occasionally the same on both the Barracuda &  Challengers models, but the upholstery patterns were different. So, the sheets printed in the trim shop were typically marked B for Barracuda or C for Challenger so the correct upholstery pattern was used.
 Some also have an X, W or B etc. after the first letter to note the color.
Offline cudafishin
« Reply #2 on: July 21, 2009 - 06:22:33 PM »
Thanks Barry!  I think many, many Mopar owners would agree that you are the
Dalai Lama of Mopar VIN decoding, build sheets, and mating original douments with their rightful owners.  A small piece of my broadcast sheet is missing, but I forgot to check the back of the glove box liner for another sheet.  I'll be doing that tonight!
Thanks again!
Offline 422STROKER
  • Member Since 6/3/06
« Reply #3 on: July 21, 2009 - 07:58:35 PM »
 :dunno:have both sheets for mine, one has a "C" the other a "Bc" as far as I can tell.  Car is a Challenger.
Tom
Tom
Alaskan_TA
« Reply #4 on: July 21, 2009 - 08:55:55 PM »
The glove box sheets often have numerous markings.
Tom, if you have a scanner, shoot images of both of them to me in an email & I can take a look at them for you.
Offline 422STROKER
« Reply #5 on: July 21, 2009 - 09:17:15 PM »
I'll try and get a copy  of each. I found one under the rear seat(Bc) and one in the front seat back (C) both match the VIN of my car.
Tom
Tom
