Author Topic: 904 slipping?  (Read 1198 times)
Offline Glennster
904 slipping?
« on: July 22, 2009 - 06:23:25 AM »
My 904 tranny is slipping a little as it goes into second gear. It only does it at high RPM under power. The lower speed normal driving is not a problem.
 I've got plenty of new fluid...........
Is there a cheap easy fix that I can do?
THANKS for any suggestions!
Offline tactransman
Re: 904 slipping?
« Reply #1 on: July 22, 2009 - 08:01:32 AM »
You can try adjusting the band.
Terry-tactransman
Union, Mo.
Offline Glennster
Re: 904 slipping?
« Reply #2 on: July 22, 2009 - 05:40:31 PM »
How do you adjust the band?
It that some I can do myself?
Offline tactransman
Re: 904 slipping?
« Reply #3 on: July 22, 2009 - 05:45:25 PM »
Yup.
Loosen the lock nut (3/4 size) right above the front cooler line
run the adjustment bolt in snug (72 in/lbs.)
back it off 1 1/2 turns and hold it while you tighten the lock nut back up.
Terry-tactransman
Union, Mo.
Offline Glennster
Re: 904 slipping?
« Reply #4 on: July 23, 2009 - 06:38:08 AM »
I think even a Lug Nut like me can do that!
THANKS again to tactransman!!!!
Offline Glennster
Re: 904 slipping?
« Reply #5 on: July 23, 2009 - 08:58:43 PM »
That thing is a little tricky to get to. After trying many combinations of sockets, swivels and extensions, I got the lock nut free.
 It was about 5 turns in before that bolt got snug. I made the adjustment and took her for a ride. It slips a little more now than it did before.
  2nd gear to 3rd seems like there's no slip.
When I rev it high in 1st and shift to second, it slips for a second or so and then hooks up. But there is a big delay as it's trying to hook up.
Did I do something wrong or it it just too tired?
THANKS for the help!
Offline tactransman
Re: 904 slipping?
« Reply #6 on: July 23, 2009 - 09:38:47 PM »
It sounds like the band is shot. How many threads were showing on the adjustment bolt when it got snug?
Terry-tactransman
Union, Mo.
Offline Glennster
Re: 904 slipping?
« Reply #7 on: July 23, 2009 - 11:09:58 PM »
1, maybe 2..................
This is going to be expensive isn't it?
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
Re: 904 slipping?
« Reply #8 on: July 24, 2009 - 03:01:34 AM »
The front band itself is pretty cheap but you should also check if the front servo is ok. I also recommend polishing the front drum if the band is burned.
http://www.transmissionpartsusa.com/A500_42RE_transmission_band_p/530-00053997b.htm
Offline Glennster
Re: 904 slipping?
« Reply #9 on: July 24, 2009 - 05:44:57 AM »
What is the servo and how do you check it?
Can a rookie like me change the band?
I assume I have to remove the tranny to do that???
I was going to drive to a car show (2 hour drive) Saturday, is this thing about to die on me?
