Author Topic: panel welding  (Read 939 times)
Offline 72cudamaan
panel welding
« on: July 22, 2009 - 09:42:05 PM »
Looked through the archives and didn't find much. Are most people mig welding their panels;? How about these cheap spot welders. Anyone use it good/bad? :feedback:
If I cant fix it, it's broke
Andy  (phukker whither)
wagesofsin
Re: panel welding
« Reply #1 on: July 22, 2009 - 10:11:25 PM »
i mig everything, even "recreate" spots.
http://www.cuda-challenger.com/cc/index.php?topic=53665.0
heres what i did via mig.
or you can just go to the web icon in my sig, and forgo all the yakking.
hope it helps.
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
Re: panel welding
« Reply #2 on: July 22, 2009 - 11:10:05 PM »
All MIG welding here as well.  I plug welded to re-create the spot welds in a 1-piece floor and other similar panels.  Works really good and looks good when done.  You can see pictures on my website.
Daniel
www.ebodyproducts.com
dj1965@ebodyproducts.com
Offline dutch
Re: panel welding
« Reply #3 on: July 23, 2009 - 01:21:52 PM »
mig.
I`d not buy the cheapest welding machine.  esp. when your ride needs a lot of metalwork done, you really want a decent welder.   :2cents:
*** Bart ***
Offline grimmey71
Re: panel welding
« Reply #4 on: July 23, 2009 - 06:39:03 PM »
Offline AMXguy
Re: panel welding
« Reply #5 on: July 25, 2009 - 09:52:33 AM »
I use a small wire feed with a gas shield and it works great.  I butt weld with the stitch method and it seems to work fine, don't use flux and keep it cool thats the two most important things I can say.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline 73Barracuda340
Re: panel welding
« Reply #6 on: July 25, 2009 - 10:41:08 PM »
I use a Hobart Handler 120 for most of my panel welding.  For heavier welding I use a Hobart TigWave 250 (it can do stick, MIG, and TIG as well).  My Handler is setup for .024 solid wire with straight CO2 shielding gas.  This gives me the best weld on thin guage sheet steel without burning through the panel.
When welding sheet metal, I keep a bucket of cold water and a rag nearby to keep the panel cool as I go.  Minimizes warping that way.
Brian
