Author Topic: How to figure air cleaner heighth?  (Read 577 times)
Offline shadango
« on: July 23, 2009 - 11:11:59 PM »
Right now I have a 10"x 2"  edelbrock air cleaner with a paper element.
I want to get a K&N /reusable type that flows better....one that is taller and has the "open" top.
What is the best way to figure out how high a filter  (total height) I can go?
What tricks do you guys use?
Re: How to figure air cleaner heighth?
« Reply #1 on: July 23, 2009 - 11:22:27 PM »
ball of play dough on top of your current filter top...close your hood measure the dough & that's how much extra space you have.
Offline LAA66
« Reply #2 on: July 23, 2009 - 11:34:40 PM »
 Don't forget the difference in base heights if changing the whole unit. :2cents:
Offline shadango
« Reply #3 on: July 24, 2009 - 08:32:02 AM »
Yeah....in fact I was all over a setup that was for sale here, but I have an eddy carb and cant use a 'drop' style base.... :swear:
« Reply #4 on: July 24, 2009 - 08:36:35 AM »
You could get a 10" K&N element that is taller...Should be sufficient, doubt your car would see an advantage from the filter top.
Offline shadango
« Reply #5 on: July 24, 2009 - 08:41:06 AM »
I may have to go slightly bigger...not sure I have the heigth...thats why I was thinking of going with the top...to gain the additional surface area/input that I cant get from going up.
Plus, it looks cool.  LOL   :2thumbs:
« Reply #6 on: July 24, 2009 - 09:27:49 AM »
I'll just throw this out there FWIW... Not long after I joined C-C.C a member, CODY if i recall, had a cool looking open top oiled foam filter that after a backfire went up in flames, luckily his hood was up and the only real damage was to the filter.   Now it must not be a common occurrence or even an issue with the K&N but I don't really want oil soaked cotton exposed to a free supply of oxygen sitting on top of my carb.  :2cents:
Offline shadango
« Reply #7 on: July 24, 2009 - 09:38:08 AM »
Hmmm...thats an interesting point.
Like you said, maybe not a real big deal if K&N is selling them...seems like it would have to be a true carb fire (not just a backfire) to actually be an issue...at that point, any oil-soaked filter could go up in flames I suppose......
But...hmmm.
If I can just go a big larger in diameter and a bit taller I would be ok with it.......
