Author Topic: 73 Challenger Painted 12-31-11  (Read 49369 times)
Offline dutch
Re: New 73 Challenger project
« Reply #75 on: September 23, 2010 - 05:50:18 PM »
won`t be long now....  :jumping:
*** Bart ***
Offline 71340RT
« Reply #76 on: September 25, 2010 - 01:39:40 AM »
I bought a few items at Monster Mopar weekend and have them ready to install along with new hood hinges, hp 68-70 exhaust manifolds and a 489 case 323 sure grip 3rd member. I had to have new bearings put in the 3rd member and had the suregrip unit checked out. I painted the 3rd member and some of the small items so here are some pictures.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline 71340RT
« Reply #77 on: October 09, 2010 - 11:22:09 PM »
Got some more work done on the Challenger this week. I put the 3rd member 3.23 suregrip rear end put in and put the engine together and even got it painted. With any luck I'll get the engine and transmission put in in the next week. Here is a picture of the painted engine just about ready to put in.
Offline 74ralley
« Reply #78 on: October 09, 2010 - 11:50:02 PM »
 :2thumbs:  Looks Great!
The Only Easy Day, Was Yesterday.
Pennsylvania
Offline jrwoodjoe
« Reply #79 on: October 10, 2010 - 08:54:00 PM »
That's a great idea for painting the rear diff unit. I've got to paint mine very soon so I may steal that idea.  :bigsmile:
Keep the pics coming. It's looking fantastic.  :cheers:
65 Barracuda
70 Challenger
Offline Mentally Challenged
« Reply #80 on: October 10, 2010 - 10:32:58 PM »
Coming along nicely Jeff  :2thumbs:
Chris, Ohio
Offline 71340RT
« Reply #81 on: October 30, 2010 - 08:29:07 PM »
I got the engine and transmission installed today as it got up to 75 degrees so I thought I better get the two put in. I installed them as a assembly together and the only problem was one of the new motor mounts was not threaded and I had to take it off and fix it. My cherry picker was having problems raising up and I thought it was low on oil as it has happened before but this time it did not fix it. I borrowed one and got the engine in anyway. Here is a picture of the engine compartment with the engine in.
« Reply #82 on: October 30, 2010 - 10:03:23 PM »
Man I need a dose of whatever your taking....Great Work  :thumbsup:
Offline 71340RT
« Reply #83 on: October 31, 2010 - 10:28:06 PM »
I got the exhaust system out I got last week from Dale's Cuda shop. I got everything from them except the exhaust tips which I had already bought stainless steel exhaust tips. Here is a picture taken in my basement as I get everything ready to put on the challenger.
Offline hezzel
  • Matching numbers 383 Magnum ,727 at and 3:23 rear
« Reply #84 on: November 01, 2010 - 02:36:35 AM »
Sweet work  :2thumbs:
1971 Dodge Challenger R/T
2019 Toyota Rav4 Hybrid
Offline Chlngrcrzy
« Reply #85 on: November 01, 2010 - 09:04:47 PM »
Did you go in through the top with your engine or installed with your k-member and lower the car down on top of it?
Offline 71340RT
« Reply #86 on: November 01, 2010 - 11:22:18 PM »
I lowered it in from the top with a cherry picker. I hook the engine and transmission together and tilt the engine with the body jacked up in the front and on the ground at the back wheels. Works well and I have done it 4 times now with no problems. Saves having to get under the car and hook the transmission up as I'm getting to old for that. I had the mounts bolted up in less than 45 minutes.
Offline Chlngrcrzy
« Reply #87 on: November 02, 2010 - 10:47:19 AM »
I have heard that a lot of guys will remove their k-member and bolt everything on there first.  Do you bolt on your exhaust manifolds before lowering it into the bay?
« Reply #88 on: November 02, 2010 - 11:40:50 AM »
There is really no right or wrong way to do it.  If you want to do it like the factory, all of the accessories should be bolted on.
The LCA's were installed along with the front swaybar(if equipped)  The spindles with the rotors/drums were also installed.  The engine was completely assembled including manifolds, carb, distributor, and all pulleys/pumps/belts.  Cars may have had the upper/lower rad hoses installed as well.
The drivetrain was installed very close to the end of production.  Components in the engine bay would already be inplace.(wiring, hoses, master cylinder, wiper motor exc...)
Like I said, there is no right or wrong way of doing it.  This car is coming together nicely. :thumbsup:
Offline B5barracuda
« Reply #89 on: November 02, 2010 - 02:19:40 PM »
Looking great Jeff,keep up the good work,see you soon.
2010 CHALLENGER S/E DEEP WATER BLUE
1970 CORONET 440 FOUR SPEED 30K ORIG MILES
1969 SUPERBEE 383 AUTO 99 PAINT CODE
1996 INDY RAM PACE TRUCK
