Author Topic: Correct throttle bracket for 4 barrel?  (Read 1241 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
« on: July 28, 2009 - 01:54:31 PM »
 :clueless:
As I was assembling my throttle linkage assembly, my friend came over to give me a few pointers. I greatly appreciate and respect his advice. He knows the ins and outs of these Challengers so well it truly blows my mind.
One thing he pointed out to me that I need to correct is the throttle linkage bracket.
The one I have in the car is correct for the 2Barrel carb, but not the four.
It seems like the throttle cable would bind, as it is agled to far over. It appears as though I need this:
I found a picture of the 4bb bracket ....
http://www.megapartsusa.com/proddetail.asp?prod=101-TB060
I see there is a special adapter kit from Buchillion performance, but I am not quite sure if that is the ticket.
Anyone ever used this kit? Does this kit adapt a 2bb toa 4bb throttle linkage?
http://www.bouchillonperformance.com/BPEtkdcInstructionsNEW.asp
This is one that I have: (2bb)
http://www.bouchillonperformance.com/images/Figure5B2.jpg
Dan
Re: Correct throttle bracket for 4 barrel?
« Reply #1 on: July 29, 2009 - 01:36:22 AM »
I don`t know which carb you have but both Eddy & Holley make a linkage adapter for mopar applications the Holley part # is 20-7
 the bracket from Mega parts should work but Mancinis also has brakets to adapt for the 4 bbl
Offline DMZ73
« Reply #2 on: July 29, 2009 - 08:11:16 PM »
Thanks chryco, I figured someone would have something close by.
I don't like the adjustable ones. I thought mancinis only sold those.  :dunno:
I just think I should do the 4 barrel bracket.
I have the edelbrock performer2 intake, and 690cfm carb ..
Dan
Offline DMZ73
« Reply #3 on: August 02, 2009 - 02:06:19 AM »
I was mistaken, I need to find this one:
anyone know where I might get one?
Offline 67vertman
  • Member since 9-23-2005
« Reply #4 on: August 02, 2009 - 04:05:16 AM »
Hi DMZ73, I got mine from the junk yard, $5, It was off a pick up truck.
Offline DMZ73
« Reply #5 on: August 02, 2009 - 09:23:02 AM »
I'm thinking the same thing you are.
My only problem is taking the time to get to a good yard, pull one off, blast it clean...
I'll be in it far deeper than the time I have left.. :banghead:
I might just spend the money and get it ASAP. Wish I would have known ahead of time.
I could make it work if I knew how the 340 shift/kickdown linkage worked.
Dan
