Author Topic: 440 stumble need help please!!  (Read 1026 times)
Offline challngd73
« on: July 28, 2009 - 06:37:06 PM »
Hello, My 440 had a stumble off idle, so I rebuilt the grungy 750 eddy to no avail.  the car starts right up, idles perfect, in gear and in park.  but if i give it a little throttle, is sputters and bucks.  seems ok if i give it more gas, it is just at low throttle.  even if im driving down the road, and get to speed, and back off the throttle, it does it then to.  any thoughts?  please?!
Offline 71chally416
    • The Streetwalker
Re: 440 stumble need help please!!
« Reply #1 on: July 28, 2009 - 07:00:21 PM »
When you look down the carb with the engine off does it shoot gas out the pump nozzle with the slightest throttle movement? And does it give a steady stream of gas when you open the throttle??   :popcorn:
Offline challngd73
« Reply #2 on: July 28, 2009 - 07:17:39 PM »
yes it does on both counts.
Offline Fleet 500
« Reply #3 on: July 28, 2009 - 07:37:32 PM »
Could be the accelerator pump.
My '66 Fury VIP also has a hesitation at low speeds.
I looked in the carb and pulled the throttle a few times. I saw fuel squirt into the carb but it didn't seem like a strong stream like it should be.
I haven't done anything about it yet but will post when I do.
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #4 on: July 28, 2009 - 08:20:31 PM »
Get rid of the Eddy. I had the same problem with mine. I put on a Holley 750 Street HP. problem went away!!
                                                  Matt B.
Matt
Offline challngd73
« Reply #5 on: July 28, 2009 - 09:19:31 PM »
id love to get rid of the eddy, but all i have other thn that is a 600 doublepumper holley..
« Reply #6 on: July 29, 2009 - 01:39:43 AM »
well Eeddy has 3 holes on the pump arm , try moving the rod 1 hole away from the carb , also they have 3 different shooter sizes so you can buy the set & use a larger squirter to get more fuel in as the carb is opened .Trick # 3 is to advance the timing a few degrees at idle , this will often cure an off idle stumble
Offline challngd73
« Reply #7 on: July 29, 2009 - 11:57:08 AM »
thanks chryco, i'll give it a try.
« Reply #8 on: July 29, 2009 - 02:48:21 PM »
Let me Know how it works out
Offline challngd73
« Reply #9 on: July 29, 2009 - 05:40:16 PM »
ok Chryco, I went right to step 3 and checked the timing....it was at 20...I set it to 10(although it is jumping between 10 and 12), and the hesitation is about 90% gone.  thanks for the help.(didnt think the timing was an issue since it started up so quickly and idled so well, but that was it!)
« Reply #10 on: July 30, 2009 - 03:43:04 AM »
cool
 usually i find the opposite where the timing is not advanced far enough & it will bog
Offline dwbiggs
« Reply #11 on: July 31, 2009 - 01:46:57 PM »
Wow...stumble problem with Eddy...who woulda thunk it?
Offline Fleet 500
« Reply #12 on: July 31, 2009 - 02:51:43 PM »
Is "Eddy" short for "Edelbrock?"
Offline 71chally416
    • The Streetwalker
« Reply #13 on: July 31, 2009 - 04:49:56 PM »
YES.
Apparently it isn't even the carb causing the stumble. I've had plenty of Holleys that stumbled and leaked and wouldn't idle right and had every imaginable malfunction. It's because of the first rate quality in China.   :smilielol:
