Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
The Good Stuff
Ebod Pics
(Moderator:
69ChargerRT
changed my cars stance, opinions?
« previous
next »
Print
Pages:
1
2
Author
Topic: changed my cars stance, opinions? (Read 3319 times)
bugsydog
Jr. Member
Re: changed my cars stance, opinions?
Reply #15 on:
July 30, 2009 - 01:44:18 PM »
Car looks great, i also love to see them in the weeds
Logged
Oz-E-Body
Jr. Member
It's Alive!!
Reply #16 on:
August 01, 2009 - 09:24:26 AM »
Looks much better with the lower stance, nice work!.
Can someone please explain how this is done (what adjustments etc) I might do the same to my ride.
Thanks
Logged
73Chally
Resident
Reply #17 on:
August 01, 2009 - 09:32:25 AM »
Front end is lowered using the torsion bar adjusters (3/4" bolts that face down through the lower A-Arm), but only use this to lower it no more than an inch or so, otherwise you will really screw up suspension geometry's. The rear can be lowered with new leaf springs or a lowering kit.
Logged
miketyler
Resident
Reply #18 on:
August 01, 2009 - 01:17:12 PM »
I happened across an episode of Nash Bridges yesterday. Man, that car had a LOT of ground clearance. I think all four tires were fully exposed. Raised has an aggressive look. Even with the 15's on that car it looks like you could walk under it with your hat on. Proably nice for doing any work on the creeper
Last Edit: August 01, 2009 - 07:38:14 PM by miketyler
Logged
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
challngd73
Jr. Member
Reply #19 on:
August 01, 2009 - 02:53:04 PM »
Logged
73Chally
Resident
Reply #20 on:
August 01, 2009 - 05:44:24 PM »
Did you lower the front some more? Now to me it looks a little too low in the front. I would either go back up a little, or get to work on lowering the rear.
Logged
challngd73
Jr. Member
Reply #21 on:
August 01, 2009 - 06:17:39 PM »
no, I didnt lower it anymore...but I will probably bring it up a hair more, as it just barely rubs at full lock. I will lower the rear sometime this month.
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #22 on:
August 01, 2009 - 06:34:38 PM »
Did you check the bumpstops? Looks good, how old are the rear springs? They may settle a bit if new.
Tom
Logged
Tom
challngd73
Jr. Member
Reply #23 on:
August 01, 2009 - 06:42:47 PM »
I havent checked the bumpstops, where are they? And the rear leafsprings, I have no idea how old they are, the guy I bought the car from wasnt very knowledgeable of the car. They dont look new, but arent rusty or anything either.
Logged
73Chally
Resident
Reply #24 on:
August 01, 2009 - 07:32:58 PM »
The bumpstop is a triangular piece of rubber up inside the wheel well that the upper suspension will hit when compressed. If you push down on your front end, how far does it go before you hear a thud and it won't go down any more?
Logged
GoodysGotaCuda
Sr. Resident
Reply #25 on:
August 01, 2009 - 07:48:56 PM »
Lower it more, this is pretty much stock with decranked torsion bars up front. 295s in the rear and 255s up front really fill things up though..
Logged
Build Page:
Goody's 'Cuda Build Page
1976 Dodge Warlock
Wheel & Tire Specs:
Link
sassygrass72cuda
Jr. Member
Reply #26 on:
August 26, 2009 - 01:35:43 PM »
I was going to run 17's and 18's on my barracuda but went with 17's at all four corners. In my opinion it looks way better now that before. Lowering the back would look good to.
Logged
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
The Good Stuff
Ebod Pics
(Moderator:
69ChargerRT
