News:
Yes, but Summit also offers SUM-7074CH which is their house brand stock height spring (which they claim is correct for your car's OEM engine and weight rating. It is a 5 leaf spring) as well as SUM-7074CH-2 which is a 2 inch drop spring, also 5 leaf. Since most stock mopar springs have very little arch in them by design, these may be down around 1-1.5 worth of arch in the installed position.If you want to go even lower, Mopar offers their zero arch oval track springs, P4452414. These are a four leaf design, but the leaves are 9/16 thick instead of 7/16 like stock, and they have a 1.5" shorter front segment like a super stock spring.If you want the drag racing look like bentpshrods and 71Ply then you would want to get Espo's +1 set up.
