Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
how can I find out if my rear axel 8 3/4 have positraction with out dismantling
« previous
next »
Print
Pages: [
1
Author
Topic: how can I find out if my rear axel 8 3/4 have positraction with out dismantling (Read 752 times)
svenjorgensen
Jr. Member
on:
July 31, 2009 - 05:51:17 PM »
Hi
I hope some one can tell my how to see if my 8 3/4 has positraction. It is with a 1 3/8 pinion.
When the car is on jacks and I turn one wheel the other turn the same way! That lock is that what is called positraction or sure grip?
thanks Sven
Logged
340_6pak
Jr. Member
Re: how can I find out if my rear axel 8 3/4 have positraction with out dismantling
Reply #1 on:
July 31, 2009 - 06:08:57 PM »
I was told that if the wheels turn the same way it is a sure-grip.
Logged
73 Challenger
340 6pak
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #2 on:
July 31, 2009 - 06:52:06 PM »
Yes, you have a sure-grip!!
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
wagesofsin
Guest
Reply #3 on:
July 31, 2009 - 07:16:18 PM »
yepper!! its a sure-grip
way to go!!
Logged
Moparal
Permanent Resident
Reply #4 on:
July 31, 2009 - 07:41:03 PM »
741 housing if it isnt tampered with will have a clutch type sure grip. And that is as good as you get for durability , it is rebuildable to
Logged
quapman
Resident
Reply #5 on:
July 31, 2009 - 07:48:36 PM »
Sure enough, it's a sure-grip!
Where's your pinion snubber? (Rubber bumper type thing that bolts to the top of the housing)
Logged
72bluNblu
Sr. Member
Reply #6 on:
July 31, 2009 - 08:40:57 PM »
If it hasn't ever been apart then its a Sure Grip. But if it has been apart it could also be a spool (if it was a racer). Of course if it was a racer it probably wouldn't still have a 741 case, so you've probably got a sure grip.
Logged
svenjorgensen
Jr. Member
Reply #7 on:
August 01, 2009 - 02:46:33 PM »
Thanks
Logged
Kevin71
Full Member
Reply #8 on:
August 02, 2009 - 06:11:33 PM »
I have a 83/4 rear end. It roars some and only one wheel spins. Could the clutches be worn out preventing the other wheel from turning. Also if I jack it up should both wheels turn if the clutches are worn out.
Logged
72cudamaan
Resident
Reply #9 on:
August 02, 2009 - 07:12:37 PM »
are u sure it is even a posi unit?
Logged
If I cant fix it, it's broke
Andy (phukker whither)
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
