Author Topic: Never mind- brake lines and rebuilt calipers- problem solved!  (Read 1189 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
 :villagers: :swear: :stomp: :pullinghair: :banghead:
I bought a full brake line kit from inline tube. I had my brake calipers rebuilt locally.
I bought generic brake lines from the shop that rebuilt my calipers.
 :swear:
The brake lines will not go in without removing the forward spindle bolt. That means either of 3 things.
1.) the brake calipers are different
2.) the  brake lines are different
3.) I need to peel apart the front spindle to get these damn things on.
 :1zhelp: :dunno:
The rear brake hose also came with an integrated proportioning block. I know that that is not right.
Advice appreciated.
Thanks!
Dan
Anyone had a similar issue to report?
« Last Edit: August 01, 2009 - 04:37:10 PM by DMZ73 »
Re: Aftermarket brake lines vs rebuilt calipers HELP!!!!
« Reply #1 on: July 31, 2009 - 09:46:28 PM »
Are you sure you have the calipers on the correct side?
Offline DMZ73
« Reply #2 on: July 31, 2009 - 10:24:30 PM »
 :pullinghair: :screwy: ;)  :lol2:
 :roflsmiley: :roflsmiley: :roflsmiley:
 :faint:
your right... I have em on the wrong side...
 :clapping: :thumbsup:
I thought the brake nipple was a little low... it certainly looked a little awkward...a picture is worth a thousand words...
Many thanks!!!!
Dam
« Reply #3 on: July 31, 2009 - 11:32:57 PM »
In the words of One Famous Forum MEKmber .....Don't ask me how I know  ::)
Offline Aussie Challenger
« Reply #4 on: August 01, 2009 - 05:58:06 AM »
  Very easy to do, but only done once...    :cheers:
Offline DMZ73
« Reply #5 on: August 01, 2009 - 04:33:19 PM »
Thanks guys. Pictures work well. Memory can be flawed...
Brakes are on, ready to drop brake fluid. I will finish the e-brake connections first, then I will have brakes!!!
It will be the first time in 15 years!
Dan
Offline shadango
« Reply #6 on: August 05, 2009 - 10:46:23 AM »
I did this way back once when I was installing new calipers on my folks' 89 Reliant wagon......couldnt figure out why I couldnt get a good bleed on them.......
DUH...the nippes are facing down......!!!!!
LOL :banghead:
Re: Never mind- brake lines and rebuilt calipers- problem solved!
« Reply #7 on: August 05, 2009 - 01:05:53 PM »
LOL :banghead:
Just remember.....Nips UP     :bananasmi
