Author Topic: Vacume advance  (Read 703 times)
Offline CUDA JAS
  • vroooooom!
Vacume advance
« on: August 02, 2009 - 10:53:57 AM »
So i like running that vacume advance on my 360 (it improves gas mileage a bit).
But, when I run it, the car surges badly under light throtle cruise.
I think the vac can is adjustable.  Would the surge be caused by to much advance or to little.
Any help would be appreciated.
Jas
74 'cuda 360/727
Just call me a gearhead!
Offline BIGSHCLUNK
Re: Vacume advance
« Reply #1 on: August 02, 2009 - 11:13:52 AM »
No expert here for sure but are you taking vacum off the correct port. The one w/o vac at idle..  :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline CUDA JAS
  • vroooooom!
Re: Vacume advance
« Reply #2 on: August 02, 2009 - 11:33:53 AM »
yep
no issues at idle  only part throtle
jas
« Last Edit: August 02, 2009 - 11:45:47 AM by CUDA JAS »
74 'cuda 360/727
Offline Changin Gears
Re: Vacume advance
« Reply #3 on: August 02, 2009 - 11:41:56 AM »
Surge can be caused by too much advance.
Offline BIGSHCLUNK
Re: Vacume advance
« Reply #4 on: August 02, 2009 - 11:46:08 AM »
Did you set your timing w vac adv disconected?
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline CUDA JAS
  • vroooooom!
Re: Vacume advance
« Reply #5 on: August 02, 2009 - 11:47:42 AM »
Yes.  the car does not surge when the vacume advance is disconnected.
Jas
74 'cuda 360/727
Offline CUDA JAS
  • vroooooom!
Re: Vacume advance
« Reply #6 on: August 02, 2009 - 11:48:22 AM »
Cool, I will try pulling some out,
Jas
74 'cuda 360/727
Offline the_engineers
Re: Vacume advance
« Reply #7 on: August 03, 2009 - 04:57:54 PM »
I'm having the same problem.  How do you adjust the vacuum advance?  I've got the MP distributor from the Elec. Ign. conversion kit.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Re: Vacume advance
« Reply #8 on: August 03, 2009 - 06:39:28 PM »
small allen wrench inserted into the vacuum nipple , counterclockwise reduces advance
